95 monte carlo z34 help
Old Dec 17, 2010 | 05:00 PM
Harleyldraper's Avatar
Default 95 monte carlo z34 help
my 95 monte z34 has a ruff idle on cold start goes from 1000 to 3000 im trying to diagnose it so i can buy the part and be done with this problems i had codes pulled and said it was iac. put new iac didnt fix problem i cleaned maf sensor still didnt fix it surges until warm then check engine light is on but that goes away after one tap on the gas so i think im gunna need to buy a code reader. also i dont know if this helps but going up hill or just somtimes i hit the gas downa dn the rpms gauge doesnt move and doesnt have full power. the car has 190,000 miles to bhe more specific and i just want to solve this problem soon. i have been told it could be upper intake gaskets, coolant temp sensor, egr valve , maf sensor and ect once warm it runs great
Old Dec 17, 2010 | 05:10 PM
mrl390's Avatar
Sounds to me like you have a vacuum leak somewhere. Get the code read first, it may tell you alot.
jmichael67
Feb 25, 2011 01:55 PM
pimpnpremium
Feb 5, 2010 08:41 PM
quadracer960
Oct 3, 2007 09:45 AM
full_monte
Sep 11, 2007 09:00 PM
shibby600cc
Mar 12, 2007 11:24 AM
