6th Gen ('00-'05): 4th Gear Problems?
i wouldent drive all the time in third do to our trans will fail even faster i will try dropping the pan and see if there is any forren mattereal in the pan or smell of bad fluid. but i will change the fluid first then it might be the shift silinoid or some thing else going wrong.
i forgot who sells the transpan that has a nut on it i know mamonte has one i also like to get one. i would sugest to do anouther one just to have the satisfaction on getting the rest on. but on the bright side at least you got what you could out. and it should run alot better with the older fluid out and the new stuff in
thats great to hear it sounds like it needed the change what i meant on doing it again is after about 3k ill do it again i had to do it to mine because of a line broke on mine and water got in thats why i did mine twice to make sure i got it out. i hit a puddel when i noticed it leaking got it fixed and changed it when it was in the shop then again after
Hello. I have a 2000 ss and for over a year I have not had overdrive. Does anyone know what would cause this? I have been told it could have something to do with my brakes but my fiance wants me to sell it so he doesn't want to do the work to fix it. I love my car even with all its issues and would like to know if it would be something cheaper to fix or get another car.
Im having a problem with my car feeling bogged down in 3rd shifting to 4th my rpms will drop far too low between 900 and 1100 while im still accelerating hard. If I try giving more gas it drops my rpms even further feeling like im hauling a boat uphill . It doesnt get better unless I let off the gas then firmly resume acceleration. Any ideas would be great I recently did trans fluid drain new filter and new solenoids however I had the car scanned and they said its throwing no codes and they said the transmission appeared to be running fantastic. Any ideas please !!!
6th Gen ('00-'05): 4T60 4th Gear
Chief Monte
Oct 17, 2013 08:09 AM
6th Gen ('00-'05): gear set, 4th gear hub, channel plate gouged! help!
turbo monte
Apr 4, 2013 10:01 AM
el402
15
May 27, 2012 10:04 AM
24_48Fan
Apr 19, 2008 07:48 PM
