4T65HD Conversion
Old Sep 19, 2012 | 11:39 AM
The only reason I could see re-flashing the PCM is if something was no longer stock in the trans (such as changing gearing ratios). Otherwise, the PCM should not care about it if it's equal to factory.
I'd be suspescious of what they are doing with a rebuild it a PCM flash is *required*.
Old Sep 20, 2012 | 07:44 PM
monte07's Avatar
hay i have a trans from them the only thing i had to do is swap out the wheel speed sensor it was not matching the speed i was going i was doing 70 when the speedo was saying 65. thats it to be honest .
bumpin96monte
Sep 13, 2013 10:57 AM
Bigg J
May 22, 2006 03:28 AM
95monte
Mar 19, 2006 02:54 AM
White05LT
Feb 28, 2006 11:41 AM
the4thlast1
Apr 26, 2005 08:41 PM
