3500 to 5.3 V8 Swap
Old Sep 18, 2012 | 10:14 PM
01MoneyCarloSS's Avatar
Default 3500 to 5.3 V8 Swap
What parts are needed to take the 3500 out my 2006 LT and swap it with 5.3 V8? Is there a step by step on how to do it?
Old Sep 18, 2012 | 10:19 PM
Mr Grizzly Mint's Avatar
need all wiring harnesses, dash gauge cluster, engine and transmition, pcm, tcm, and some other stuff one guy did a 3.8 to 5.3 on the 6th gen. was like 4-5k in junkyard parts.
Old Sep 18, 2012 | 10:26 PM
What is a TCM. I swapped a 3.4 dohc to 3.8 and a 3.8 to the supercharged 3.8 so i know wiring is important. Just curious on other mechanical parts are needed.
Does he have a post when he did his swap?
Old Sep 19, 2012 | 08:36 AM
They split the PCM into the ECM and the TCM. Transmission has its own control module now.
Old Sep 19, 2012 | 09:16 AM
Oh ok, so is there still a BCM under the driver side dashboard?
Old Sep 19, 2012 | 09:23 AM
Yes, there are control modules EVERYWHERE
Old Sep 19, 2012 | 09:48 AM
farmerjg's Avatar
This might be what you're looking for. This guy put an LS4 into his 2001.
https://montecarloforum.com/forum/si...per-ls4-26283/
Old Sep 19, 2012 | 10:40 AM
Lol ok. So if I cant find a donor car to gather all all my parts for the swap, is there someone where i can buy the parts from? (electrical parts)
Old Sep 19, 2012 | 10:41 AM
Thank you, im going to check it out now.
Old Sep 19, 2012 | 11:33 AM
That Monte Carlo "01 MC SS Sleeper LS4" is amazing
I was hoping he had a parts list posted. Im sure I wont need every part he needed seeing that I already have the 7th gen Monte.
