402 bbc limits
Old Mar 5, 2007 | 04:17 PM
bbcseeker's Avatar
Default 402 bbc limits
i have a 1971 402 bbc with block #3969854,also have a moroso 8qt.oil pan that works with up 4.25" stroke.my goal is tochange it to4 bolt billet main caps,forged 10.5:1 cr,with 4.25"(or4.")stroke steel crank(6.135 rods),using crower (all roller) cam setup (a voodoo cam with 629"lift and 261 dur.),lifters,and rockers.the heads and intake are totally dressed up closed chambered ovals (#3917215)with an older torker 2 for oval topped off with a reworked mechanical sec. 850cfm carb. msd will get the firing started for a 1600 lb. street legal street-altered. the question is of displacement, i want at least 427 cid (knowing that is possible) would being closer to square on bore and stroke be better also?i would appreciate any professional engine builder's feedback,thanx
johns85mcss
Aug 7, 2015 12:14 AM
Jfusion78
Feb 11, 2015 09:29 AM
shawnmid
Feb 26, 2013 07:19 PM
cpmman
Mar 14, 2011 06:54 PM
87montelS87
Nov 25, 2010 10:52 AM
