6th Gen ('00-'05): 3800 N/A Engine overhaul!!
Old Apr 27, 2013 | 10:33 AM
turbo monte's Avatar
my good friend it making 326whp on a dynojet with race fuel and 304whp on pump fuel.
stock l67 bottom end
stock cam
stock heads
ported gen v (3.0 pulley)
intercooled
1.9 rockers
headers
built trans
A LOT OF TUNING!!!!
Old Apr 27, 2013 | 07:33 PM
hotrodss24's Avatar
Originally Posted by TMoney
Do you have the engine already?
No I don't have it, and I'm leaning away from gettin the l67
Old Apr 27, 2013 | 07:38 PM
hotrodss24's Avatar
Originally Posted by z34phoenix
Ok: So you are going to run a full L67 and your stock NA trans. Neither stock PCM will run the combo. you will need a custom pcm from one of the vendors. the main diffs are: trans gear ratio, MAP sensor, and the boost bypass solenoid.
-Harness. not needed. you can get the two missing harness pieces for less then what you would pay at a junk yard for a harness. (boost bypass solenoid, MAP sensor)
-Either PCM can be reprogrammed or used as a core for your mail order PCM. For the power level you are after I strongly recommend a custom in car tune vs a mail order PCM.
The following is how I recommend go about the power level you are after:
-Don't waist time having the engine bored or custom internals. this money can be better spent on other mods. the stock bottom end is plenty strong for even the radical builds.
-XP cam, 105# springs, double roller timing chain, new valve seals
-Gen V blower, Headers, Custom tuned PCM
this should hit your 250-300 hp mark.
My plan to reach about 300 hp is:
stock NA block.
Ported Heads w/ Si Valves, viaton seals, L76 springs, mod'd retainers
Port matched LIM w/ coolant block off for SC
Ported Gen III 3.8" pulley
Ported L67 TB and have Northstar TB to test as well
Speed Daddy Headers
Full 2.5" exhaust
Lots of tuning.
Preciate the feedback.
Old Apr 27, 2013 | 07:40 PM
TMoney's Avatar
Any reason? Just curious. Are you going to do a too swap or just pass on the supercharger completely?
Old Apr 27, 2013 | 07:41 PM
TMoney's Avatar
*top swap
Old Apr 28, 2013 | 05:54 AM
z34phoenix's Avatar
FYI. The topswaps high compression makes modding and tuning much harder and less forgiving. I chose this route because: 1) I have extensive tuning background. So I can keep it Kr free. 2) it was cheaper to get the L36 drop in with top swap kit. 3) I preferred having the 3.29 gears of the NA Trans. 4) it got the car back on the road faster while still allowing me to have time to port everything.
When I made my suggested mod list for you I was assuming you we're going L67. Another option would be the L32. Basically it's the newer series 3 L67. But you would need to change the TB as its is fly by wire.
Old Apr 28, 2013 | 10:40 PM
hotrodss24's Avatar
No,I'm just goin to swap another 3.8 N/A and start from there.
Old May 8, 2013 | 08:31 PM
TMoney's Avatar
So you're not supercharging yours?
Old May 9, 2013 | 12:17 PM
z34phoenix's Avatar
I thnk he is considering a topswap later... But doing the NA just to get it running. Which is exactly what I had to do a few years ago
TimberJohn
Nov 19, 2013 08:47 PM
joeykl66
Sep 25, 2013 09:09 AM
bizparr
May 10, 2011 07:58 AM
RickCoMatic
Mar 13, 2011 12:47 PM
osantisbon
Jun 14, 2010 03:48 PM
