6th Gen ('00-'05): 3800 N/A Engine overhaul!!
Old Apr 25, 2013 | 09:43 AM
hotrodss24's Avatar
Default 3800 N/A Engine overhaul!!
Hey GM what's up everyone, I am about to get my engine rebuilt soon, its a 2003 3800 N/A and I would like some help on what I can do to get about 250-300 base HP out of it. I want it to wake up a little. It's gonna get bored over .30, all new internals. So guys what should I get to wake it up N/A 3800. I'd really appreciate feedback, thanks.
Old Apr 25, 2013 | 09:52 AM
Mike 00LS's Avatar
Oh wow, just looked at your join date! Welcome back!
Take a glance at this thread here for some good ideas of what you can do. But trying to get near 300 HP out of a 3800 that isn't boosted won't be too easy.
https://montecarloforum.com/forum/engine-transmission-12/general-mod-plan-3800s-thanks-bumpin-24896/
Old Apr 25, 2013 | 11:34 AM
Nice Find Mike!
Thanks!!!
Old Apr 25, 2013 | 04:43 PM
hotrodss24's Avatar
Yes, I been at it for awhile. Unfortunately I won't be rebuilding my N/A, I'm goin to the supercharged swap over 😀
Old Apr 25, 2013 | 05:07 PM
TMoney's Avatar
Originally Posted by hotrodss24
Yes, I been at it for awhile. Unfortunately I won't be rebuilding my N/A, I'm goin to the supercharged swap over ��
Are you doing a top swap or a complete engine swap?
Old Apr 25, 2013 | 07:53 PM
hotrodss24's Avatar
I'm getting the complete engine, just wondering if I would need the wiring harness and computer, anyone?
Old Apr 25, 2013 | 09:00 PM
TMoney's Avatar
I believe you would need the harness but i dont know about the computer. I think you might have to adjust something in your transmission to allow it to handle the added boost pressure the L67 puts out
Old Apr 26, 2013 | 10:42 AM
hotrodss24's Avatar
Preciate it!
Old Apr 26, 2013 | 10:43 AM
TMoney's Avatar
Do you have the engine already?
Old Apr 26, 2013 | 08:16 PM
z34phoenix's Avatar
Ok: So you are going to run a full L67 and your stock NA trans. Neither stock PCM will run the combo. you will need a custom pcm from one of the vendors. the main diffs are: trans gear ratio, MAP sensor, and the boost bypass solenoid.
-Harness. not needed. you can get the two missing harness pieces for less then what you would pay at a junk yard for a harness. (boost bypass solenoid, MAP sensor)
-Either PCM can be reprogrammed or used as a core for your mail order PCM. For the power level you are after I strongly recommend a custom in car tune vs a mail order PCM.
The following is how I recommend go about the power level you are after:
-Don't waist time having the engine bored or custom internals. this money can be better spent on other mods. the stock bottom end is plenty strong for even the radical builds.
-XP cam, 105# springs, double roller timing chain, new valve seals
-Gen V blower, Headers, Custom tuned PCM
this should hit your 250-300 hp mark.
My plan to reach about 300 hp is:
stock NA block.
Ported Heads w/ Si Valves, viaton seals, L76 springs, mod'd retainers
Port matched LIM w/ coolant block off for SC
Ported Gen III 3.8" pulley
Ported L67 TB and have Northstar TB to test as well
Speed Daddy Headers
Full 2.5" exhaust
Lots of tuning.
