6th Gen ('00-'05): 3400 3.4
Old Jun 9, 2012 | 09:15 PM
sisk's Avatar
Default 3400 3.4
I just replaced the cylinder heads with new ones and all gaskets, she seems to be running good except for VERY high idle. any ideas? We have been working on our girl for two months now, we love her but we are running low on patience.........any suggestions???
Old Jun 9, 2012 | 09:24 PM
zipper's Avatar
L67 swap
Realistically though, have you checked the IAC valve?
Old Jun 10, 2012 | 12:54 AM
First thing I'd check are vacuum leaks. Get a can of starting fluid, with the car idling, mist it around all vac connections and such, listen for a change in idle.
I changed an injector once on the 3100 Grand Am and silly me, I forgot to hook up the fat vac line for the brake booster (the idle was CRAZY HIGH)!
It could be a damaged line, something forgotten, any list of crazy stuff.
Old Jun 10, 2012 | 03:49 AM
You may want to check all the all the connectors too. Sometimes they don't lock together because of the rubber in them or maybe you missed one.
Old Jun 10, 2012 | 05:25 PM
sisk's Avatar
It was a stupid thing!!!! I let the upper intake gasket slip on one side, could have kicked myself...Anyway she is running like a charm, has a little miss, and had onstar diagnosis this and they agree. I think I may have knocked a wire loose or maybe a spark plug....that's minor will tinker with her some tomorrow hopefully the rain will stop. I appreciate all the help and input!!! Thanks for everything....
Ron A
Jan 29, 2012 10:28 AM
Mikhal
14
Dec 14, 2006 01:32 AM
mista tae
Nov 29, 2006 12:41 PM
mista tae
Sep 20, 2006 01:24 AM
dickie34
Jun 24, 2006 05:34 PM
