05 3400 v6 what can fit?
Old Sep 20, 2006 | 12:43 AM
mista tae's Avatar
Default 05 3400 v6 what can fit?
hello im new to MCF, but you folks have some good information!!!! well anyway im trying to figure out what can i do to my engine from super charger to turbo it wouldn't matter which one. also the one that wouldn't require a lot of engine mods.
thanks for the time,
Old Sep 20, 2006 | 01:51 AM
z34phoenix's Avatar
Default RE: 05 3400 v6 what can fit?
well any boost will require a good amount of work to make it last. i heard a quote that sums it up... "fast cheep reliable... you can only have two" a CSC centrivugial SuperCharger i think is your best bet cause with a turbo you will need to do exhaust work. if you stay low boost you can get away with stock injectors and wont need an intercooler. i would deff recomend a tuner such as the DHP powertuner so you can properly tune the car to specs with what ever boost you get.
but for a properly setup system i would figure between $2000-4000 and then more depending on how much power you want.
Old Sep 20, 2006 | 10:18 AM
montejass's Avatar
[sm=hail.gif]
Is that not spot on....
Old Nov 29, 2006 | 12:41 PM
97silverls's Avatar
www.milzymotorsports.com
HIxArsenaL
Feb 26, 2014 03:26 PM
Ron A
Jan 29, 2012 10:28 AM
iMSeRiOuS
May 5, 2009 12:36 PM
jeffsmonte
Sep 3, 2007 02:25 PM
Lord_Hate
Jan 21, 2007 07:53 PM
