305 intake issue
Old Mar 12, 2007 | 02:09 AM
misfitmonte's Avatar
Default 305 intake issue
Im having issues removing an edelbrock performer intakeI cant remove 2 of the bolts due to there locations. i can get a socketon it but extensions andratchets wont fit any ideas guys?
Old Mar 12, 2007 | 02:29 AM
Mrrench's Avatar
Default RE: 305 intake issue
A box end wrench will work
Old Mar 12, 2007 | 02:40 AM
cant get one on it
Old Mar 12, 2007 | 01:20 PM
2000_BLACK_SS's Avatar
Have any pics of the bolts and locations to see if we can think of anything else
Old Mar 12, 2007 | 04:17 PM
88ss408's Avatar
a short socket and a 3/8 drive rachet is all you should need i have taken plenty off !!
a pic would help to what problem you a having though i am sure if we could see that some one would have a trick
Old Mar 14, 2007 | 09:17 PM
Here are pictures of the problem bolts
[IMG]local://upfiles/1908/BB6606406B5C4E6F92CDEC8FC4F2EFA6.jpg[/IMG]
[IMG]local://upfiles/1908/C180C92AB19E4AE1887040A7294E0711.jpg[/IMG]
Old Mar 15, 2007 | 11:25 PM
mickey's Avatar
ok this is real hard. LOL
use a GOOD open ended wrench.
I know it will work on there. i have done way to many of them to know other wise.
the box end should have worked also . but it wont go all the way down on there.
I had one i bent just for this and distribitors for the small blocks.
Good luck
If this dont work i guess TNT would be the next one i would try LOL
Old Mar 28, 2007 | 11:11 PM
Chucks88SS's Avatar
Did u ever get the manifold off? If not try removing the EGR block off plate in pic 1 and like said above use a top quality tool.
Also a couple other tricks, grind down the outside of a cheap box end wrench so its flat and fits in there, same with a cheap socket.
Old Mar 28, 2007 | 11:42 PM
04 Intimidator's Avatar
You could also try getting a set of wrenches with an offset angle.
Here is a kit from Sears that might help you out. One side of each wrench has the standard 15 degree offset and the other has an 80 degree offset and is made specifically for this purpose. I still recommend going with Craftsman, this link happens to use Armstrong and I've never used them before.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
thtGuy
May 7, 2013 08:09 AM
wvmontels
Feb 2, 2013 10:54 AM
fossilman
Nov 6, 2011 03:46 PM
irving216
Jan 4, 2011 09:49 AM
pizzarrhea
May 7, 2010 09:38 PM
