2006 SS Transmission is DEAD
Old Apr 28, 2011 | 11:50 PM
bwill314's Avatar
Default 2006 SS Transmission is DEAD
My 2006 Monte Carlo SS just had the transmission die at 83k miles. After 2 days the dealership still hasn't figured out exactly what the problem is.
Thank God for my extended warranty that still has 17k miles left on it. Honestly I've seen quite a few SS Monte's at transmission shops over the last 4 years. This engine is too powerful for the piece-of-**** GM transmission. I don't think I will ever buy a GM vehicle again.
Old Apr 29, 2011 | 05:53 AM
Don't just make a hate thread. You have the extended warranty, that is why they are there. GM did make a bad move by mating the 4t65e-hd to this engine since the 300HP mark is about it's failing point, but it's not like the car is a lemon. This next transmission could easily last the rest of the life of the car.
Old Apr 29, 2011 | 11:12 AM
06MonteSS's Avatar
Old Apr 29, 2011 | 11:21 AM
Hi Bill,
Sorry to read about your problem with your transmission. I feel the frustration in your words....Happy 2 read that you had a warranty...
If you will please answer the following questions to help others that have the same or similar Monte.
1. Are you the original owner ?
2. Did you ever have your trans serviced (fluid change & filter) ? If so, how many times ?
3. How did you drive your Monte S.S.
a. easy
b. Aggressively, but did not abuse.
c. Drove it hard & Raced EveryTHing : )
4. What were your first signs of problems ?
5. Did you have any mod's ?
Thanks for sharing & Good Luck on repairs.
putnamjf
Feb 18, 2013 01:33 PM
bat208
Oct 25, 2011 03:01 AM
Boomer
May 22, 2011 08:26 PM
nat120
Apr 23, 2011 10:13 PM
06BlackSS
Apr 22, 2008 08:21 PM
