7th Gen ('06-'07): 2005 monte carlo rocker arm
Old Feb 19, 2013 | 10:52 AM
texmmt's Avatar
Default 2005 monte carlo rocker arm
Hi I recently had some loud clicking noise in my car about a month after oveheating. I removed the rocker covers and I noticed that one of the rocker arms had sheared the threads in the aluminum head and was sitting in the rocker cover when I removed it.
I was wondering if it can be repaired with a heli-coil. Does anyone have any thoughts or experience with heli-coils. I was on the heli-coil site and they say it can be used for the head bolts so I was thinking taht it can be used for the rocker cover bolts as well.
Any help would be greatly appreciated
Tex
Old Feb 19, 2013 | 11:08 AM
Helo coils were a great innovation in my opinion... Since its for just repairing a rocker "cover" bolt (valve cover) I dont see it being a problem!
Old Feb 19, 2013 | 11:58 AM
texmmt's Avatar
It's not the rocker cover bolt that broke it's the actual rocker bolt itself that sheared the threads in the head. I know that I need to replace the rocker bolt because the are torqued to the yeild point.
Old Feb 19, 2013 | 12:41 PM
That maybe a whole nother issue then.. Since its the rocker arm stud...
Its worth a try vs a New head!
Good Luck hope it works out for you!
Keep us informed.
Old Feb 19, 2013 | 02:19 PM
texmmt's Avatar
Thanks for the tips I'll let you know how I make out
Old Feb 19, 2013 | 03:10 PM
You can get reusable rocker bolts
3tErNaL
21
Aug 24, 2018 08:47 AM
Aaronb425
Dec 29, 2012 09:10 AM
JohnieWalker305Blue
Jul 1, 2012 08:40 AM
mairj40
Feb 9, 2012 12:02 AM
musclecarfreak1235
Jan 3, 2011 06:29 PM
