2002 Monte SS Earnhardt Edition gear ratio
Wrong answer....all 2002 MC are 3.05, only NA Pontiac Grand Prix are 97-03 are 3.29, ZZP has this listed: ZZ Performance
this is right
it should be the 3.29 because it was N/A just like the Grand Prixs
2.93 - 97+ Grand Prix GTP, Regal GS, Bonneville SSEi, 04+ Monte Carlo/Impala SS
3.05 - Most NA cars- 04+ Grand Prix GT (non supercharged), Regal/Lasabre, Bonneville, Monte/Impala (non SS), Park Avenue
3.29 - 97-03 Grand Prix GT, 04+ GTP (Comp G only)
why would gm have different gearing for the same powertrain during that year, they're virtually the same car.
And Mike drives a car of that similar year, so I think he would know his own gearing?
Maybe we're both wrong.. But according to zzp it looks like it should be 3.29
ok so I work at advanced auto parts, I am top swapping my 02 monte ss Dale Earnhardt edition and doing front end rebuild and im also having problems finding the cv shafts or that edition of car. even though drive train is no different from the other 3.8 NA blocks however the cv shafts and fuel injectors are specific to the Dale Earnhardt edition
Just get regular replacement axles the Earnhardt edition is no different then any other l36 powered car.
You will however need l67 fuel injectors and then either solder connectors for them into your harness or find adapters possibly from zzp.
Advance auto parts computers don't know ****
6th Gen ('00-'05): gear set, 4th gear hub, channel plate gouged! help!
turbo monte
04-04-2013 10:01 AM
04chevyboy
01-29-2012 09:50 PM
