2002 Monte SS DHP file?
Member Z34Phoenix had this issue with a Camaro.
Perhaps if you shoot him a PM he can help with your OSID problem?
Check this link also: BonnevillePRO.com • View forum - Monte Carlo
good luck with that, he bought the dhp tuner about 1.5 years ago and has still yet to get accepted to that forum. he has sent many email and requests with no reply.
i signed up, didnt get a confirm email, and have tried emailing the admins for the last 1.5 weeks. not a single reply.
all i need is the file for my car, nothing more.
like i said i had a dhp, went through all of this, luckly a guy gave me his username and password so i could access the site. i got tired of messing with dhp and went to hpt and it is so much better IMO
dhp vs hpt IMO
dhp: rubbing 2 sticks together trying to make a fire
hpt: paper and a lighter
thanks for the reply, we are fully aware that DHP is no longer around, but the "secret" forums is still around, so i would think there should/would be an admin that is at least logging in every couple of months.
either way, i found what i needed anyway.
i use TinyTuner to edit the file, but my friend has the dhp tuner so when i see him next i will get the file flashed.
thanks again guys, i appreciate it.
Where are you from? VikesFan MN? Let me know if you still need a file I have a ton of them on my computer I can e-mail to you. This is just for a stock 2002 correct? It's not a top swap?
yes, i am in MN.
I ended up getting the stock files for my car so i am good to go there.
however, if you have a basic tune file, ie timing, shift points, etc then you can certainly send that my way.
