2002 Monte Carlo SS 3.8/V6 (Oil Leak)
Old Sep 23, 2009 | 01:02 PM
William3742's Avatar
Default 2002 Monte Carlo SS 3.8/V6 (Oil Leak)
I need to replace my oil pan gasket, do i need any special tools or some way to support the engine? Not having any luck using google search.
Thanks
Old Sep 23, 2009 | 11:47 PM
Yeah, you'll have to either pull the engine out, or drop the cradle. No special tools though.
Old Sep 24, 2009 | 06:51 AM
Thanks dropping the cradle sound like the best way to go.
Old Sep 28, 2009 | 08:32 PM
rgant_19's Avatar
I know that I won't take my monte to SpeedWay ever again because they tighten my bolt to my oil pan so tight, I don't want to damage anything if I was to loosen it up. Today I tried to change my own oil and seen more then just the oil pan covered in oil. Parts of the body frame from the front had traces of oil on it, as well as other components. So, my oil is leaking but I don' tknow where and how much. I need help badly!!!
BIGAL131
Sep 19, 2022 02:00 PM
Huckster
Nov 15, 2018 06:56 PM
wkimes
May 4, 2015 10:30 AM
MonteSquarlo
Dec 16, 2012 06:18 PM
jackie85
Aug 17, 2012 04:48 PM
