2000 SS Coolent trouble
Old Mar 4, 2011 | 04:11 PM
Bcrusep's Avatar
Default 2000 SS Coolent trouble
I have a small leak in my rad and i need to know where the drain plug is so i can put some stop leak in it before i have to go and buy a new one and what is needed to get it off..a socket or is it a wing tip? Thanks
Old Mar 4, 2011 | 04:34 PM
Are you 100% it's a leak in the rad?
Your drain plug is on the driver's side towards the engine and near the bottom of the radiator. There's also a piece of rubber that could just be deteriorating
Old Mar 4, 2011 | 04:44 PM
Bcrusep's Avatar
What piece of rubber? the leak is on the bottom drivers side of the rad.. do the drain plugs have a seal that goes bad on them?
Old Mar 4, 2011 | 05:13 PM
The drain plug does have a seal that COULD go bad, that's why I think you should check it out before you replace the whole radiator.
Old Mar 6, 2011 | 06:18 PM
Bcrusep's Avatar
I flushed it out and put a new O ring in it the old one looked pretty good but i dont think it was screwed on tight enough..it stopped leaking.. thanks bud.
Old Mar 7, 2011 | 04:34 PM
Glad I could save you the trouble of replacing the whole radiator!
JustKat
Feb 11, 2014 10:35 PM
daves92camaro
May 24, 2011 02:50 PM
daves92camaro
Jun 26, 2009 08:16 AM
winterkage
Jan 20, 2009 12:39 PM
JMonte
Oct 3, 2005 03:06 AM
