1995 3.4L X Motor
Old Jun 12, 2011 | 09:19 AM
monte77's Avatar
Default 1995 3.4L X Motor
I have several other W-bodies but none with the X motor, until now. I've been told that if the timing belt goes on the 95 only, the engine won't be destroyed, unlike the 96 and 97 X motors. Not that I plan on trashing this engine, and I will watch the belt, just curious.
Old Jun 12, 2011 | 10:25 AM
mrl390's Avatar
The 95 has a lower CR which results in it being a non-interference motor. The 96-97 have a higher CR and it has been debated whether or not its interference. Either way you dont want to go more than 70-80K before changing your timing belt.
Old Jun 12, 2011 | 12:31 PM
x2- a timing belt is a maintenance item, and I sure wouldn't want to wait until it broke and stranded me somewhere. If its overdue for replacement, I'd just go ahead and do it as preventative maintenance.
Old Jun 12, 2011 | 04:21 PM
monte77's Avatar
The car has 85K on it and it looks like the belt was changed once already. When we took the cover off there were no cracks, but some rubber shavings on the cover from normal wear. I am going to get it done, if I can find someone locally to do it. I've had people quote me 10 hours labor plus parts which seems high to me.
Old Jun 12, 2011 | 04:45 PM
mrl390's Avatar
I have no trouble believing it would take 10 hours for someone who hasnt worked on this motor before.
ttmillus2
Jul 5, 2011 10:28 AM
Danspeed1
Jan 12, 2007 06:34 PM
monte97
Mar 29, 2006 05:54 PM
1995chevytech
Nov 11, 2005 11:51 PM
1991BerettaGTZ
Apr 14, 2005 11:35 AM
