Timing Belt Installation on 1995 Z34 DOHC
Old Jan 12, 2007 | 05:04 AM
Danspeed1's Avatar
Default Timing Belt Installation on 1995 Z34 DOHC
Hello everyone,
I am havinga heck of a time installing a new timing belt on my Z34 3.4L DOHC V6 Monte Carlo. I made the mistake of removing the belt without securing the cams and now I have no idea how to line the cams up correctly to get this thing running again. I have the crank pulley all lined up with the arrow on the bottom and the same goes for what I believe to be the balance shaft just above that. As for the 4 cams, I have no idea how to get them lined up correctly. I do have a manual and when I look through the manual it says all the cam "flats" need to be lined up... I honestly have no idea what that means. Any help would be greatly appreciated,
Dan
Old Jan 12, 2007 | 08:33 AM
mickey's Avatar
Default RE: Timing Belt Installation on 1995 Z34 DOHC
most cams when you look at the end of them there will be a dot. try linig up the dots and installing it.
the cams have lobes on them and flats between the lobes for the lifters to ride on wha thtey are sayign is they all have to be in line.
the bad part is i dont knwo where the motor must be on this. thinking it has to be on TDC to do this for the cams etc..
Old Jan 12, 2007 | 06:34 PM
jogasz28's Avatar
There is a section in the factory manual on dealing with a broken timing belt.
jogasz28
semesic
Mar 13, 2014 08:19 PM
greg
Aug 7, 2010 09:05 AM
greg
Aug 5, 2010 04:48 PM
jogasz28
Aug 1, 2006 12:01 AM
jogasz28
Jul 20, 2006 03:28 PM
