1984 442 307 ho swap
Old Jun 10, 2009 | 01:02 AM
1986monte's Avatar
Default 1984 442 307 ho swap
i have a 1986 monte and i wanna put a 307 ho olds motor in the car what do i need?
Old Jun 10, 2009 | 09:53 AM
drewskie043's Avatar
i'm not positive on this but from what i can remember from my demo derby days i think you will need different motor mounts. i would think the accessory drive is pretty similar but if i was you i would try to poke your head under the hood of an olds so you can compare. overall, it should be a pretty straight forward swap.
oh ps- you might need an adapter plate to mount up to the 200r4.
Old Jun 10, 2009 | 11:49 PM
TheMonteMan's Avatar
your going to need an adapter for the trans. and i would take everything with the motor. just in case power steering pulley might be different. not to bother but why do you want to run that motor? the 307ho had a "hotcam" but didnt make any horsepower or torque. it was a 170hp/250tq motor when it was fresh. i had one in my gutlass and it sucked only good thing is that they were indestructible. also if you are pulling it from a 442 take the rear while your there its got the same 8.5 10 bolt that was in the grand national but with 3.73s in it.
Old Jun 12, 2009 | 10:44 AM
vincenti's Avatar
is your 86 Monte a factory V-8 or V-6 car?
Old Jun 12, 2009 | 03:42 PM
88ss408's Avatar
everything has to be changed to put a olds motor in a car with a chev motor.
no acc.will fit as they are not the same the batt. is on the wrong side. the wiring harness will have to be changed up a little the starter and alt are on the opposite side as the chevy.
if you have the th200r4 trans you have a dual bolt paturn trans so your good there.
Old Jun 17, 2009 | 02:12 AM
1986monte's Avatar
sorry i havent been on but just got the net at my house so ill be on pretty much everyday now but anyway. i have the 307 ho motor and the 350turbo trans i had to change everything from the pass to the driverside and the wiring but now its just the motor mounts hahaha cant find them anywhere i know im getting alot of crap for doing this but i just wanted to see if i could do it or not and i was short on cash so
Old Jun 17, 2009 | 02:13 AM
1986monte's Avatar
i have pix of what i did but i dont know how to put them up on the site
10YearDiff
Mar 15, 2015 08:29 AM
P343
Mar 13, 2015 12:30 PM
irulesoha
Feb 10, 2010 08:49 PM
loudNproudSS
Oct 8, 2008 12:26 PM
Jofonce
Aug 9, 2005 03:10 PM
