1979 305ci question
Old Feb 25, 2014 | 06:31 PM
79montekdw's Avatar
Default 1979 305ci question
So I am redoing my intake manifold and carburetor on my 79 with the 305. I have someone willing to give me a new intake manifold and a holley dual carb high stack setup. He had originally bought it for a 327 and I was wondering if anyone knew if it would bolt right on to my 305? and if so is it gonna be too much power?
Old Feb 25, 2014 | 06:57 PM
It will bolt up, It will not be to much power.
It will still be a 305 .. NOT A 572 big block .. LOL
Old Feb 25, 2014 | 07:30 PM
79montekdw's Avatar
well i knew that. I was just making sure it will bolt up and everything will work with it. . . other than my hood. . .
Old Feb 26, 2014 | 06:25 AM
03SSLE's Avatar
IMO installing that setup on a stock 305 will just create all kinds of headache for you. First off, you'll need to synchronize the carbs. Then you'll need to change jet size, accelerator pump actuator cam and secondary spring tension just for starters. In other words, you'll have to trim back everything the setup has to offer just to get your engine to run half way decent. Your performance gain - absolutely zero. That setup might look pretty awesome sitting between the fender wells, but unless you have an engine that can actually utilize and take advantage of the setup it's just a waste of time that will hurt performance.
Old Feb 26, 2014 | 03:08 PM
79montekdw's Avatar
well I am getting all this for free and i don't necessarily have to use the dual carb setup i can just use one of the carbs. these are the carbs I guess
Camaro Parts | HC369 | 1968-69 CAMARO/NOVA/FULL SIZE HOLLEY 780 CFM CARBURETOR | Classic Industries
Old Feb 27, 2014 | 06:31 AM
03SSLE's Avatar
If the guy is just going to give it to you then grab it. You can use it as trading material for parts you can actually use. Even a single 780cfm carb is way too big for a 305. A 600cfm - or a 650cfm carb if modified - will provide more then enough flow for a 305.
The problems you are up against is the 305/307 were designed to be smog engines. The bore/stroke combo and emission designed heads would choke off any potential performance gain you would see from a manifold/carb swap.
MonteIsA79
Jul 12, 2012 08:13 PM
Draciel
Aug 17, 2010 03:26 AM
Charlie
May 9, 2007 09:09 PM
tez
Mar 12, 2007 12:48 PM
maximum98
Dec 27, 2006 12:21 AM
