Trans Build: 1 aweomse trans build! pic heavy!
as i posted a little while ago my trans took a crap on me so i started sourcing parts that are almost unheard of to make this trans build hopefully last a long time..... here are some pics try not to drool to much ![Big Grin](https://montecarloforum.com/forum/images/smilies/biggrin.gif)
GMR aermet 800hp input shaft:
![Name: gmrinputshaft_zps913a8790.jpg
Size: 22.9 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29447d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zps913a8790.jpg)
![Name: gmrinputshaft_zps155ec5f6.jpg
Size: 43.5 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29448d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zps155ec5f6.jpg)
![Name: gmrinputshaft_zps11056b22.jpg
Size: 43.0 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29449d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zps11056b22.jpg)
![Name: gmrinputshaft_zpsbdd67009.jpg
Size: 58.0 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29450d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zpsbdd67009.jpg)
![Name: gmrinputshaft_zps9869a7ec.jpg
Size: 27.2 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29451d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zps9869a7ec.jpg)
![Name: gmrinputshaft_zps645a1444.jpg
Size: 28.1 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29452d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zps645a1444.jpg)
![Name: gmrinputshaft_zpse88542de.jpg
Size: 45.2 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29453d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zpse88542de.jpg)
now with this input shaft i needed a few grooves cut into it to be able to use it, first groove was for a nylon seal and the other groove was for a rubber o ring which is the converter seal.... some pics after being machined and seals installed:
![Name: gmrinputshaft_zps688770e0.jpg
Size: 76.4 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29454d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zps688770e0.jpg)
![Name: gmrinputshaft_zpsaed8b53c.jpg
Size: 72.1 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29455d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zpsaed8b53c.jpg)
![Name: gmrinputshaft_zps18eff6dd.jpg
Size: 56.3 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29456d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zps18eff6dd.jpg)
![Name: gmrinputshaft_zpse0ed1105.jpg
Size: 75.2 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29457d1501275193-1-aweomse-trans-build-pic-heavy-gmrinputshaft_zpse0ed1105.jpg)
next up is the GMR 300m output shaft, this is direct drop in no machining required:
![Name: gmroutputshaft_zps44d72134.jpg
Size: 40.9 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29458d1501275193-1-aweomse-trans-build-pic-heavy-gmroutputshaft_zps44d72134.jpg)
![Name: gmroutputshaft_zpsd7c231f3.jpg
Size: 45.0 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29459d1501275193-1-aweomse-trans-build-pic-heavy-gmroutputshaft_zpsd7c231f3.jpg)
![Name: gmroutputshaft_zps35298b9b.jpg
Size: 82.4 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29460d1501275193-1-aweomse-trans-build-pic-heavy-gmroutputshaft_zps35298b9b.jpg)
![Name: gmroutputshaft_zps013a081b.jpg
Size: 70.5 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29461d1501275193-1-aweomse-trans-build-pic-heavy-gmroutputshaft_zps013a081b.jpg)
![Name: gmroutputshaft_zps71c65236.jpg
Size: 34.9 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29462d1501275193-1-aweomse-trans-build-pic-heavy-gmroutputshaft_zps71c65236.jpg)
next up is a GMR 1" 3/8ths pitch chain and gear set:
![Name: gmr3111inchchainset_zpsa1de6e26.jpg
Size: 40.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29463d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchainset_zpsa1de6e26.jpg)
![Name: gmr3111inchchainset_zpsf7a99a32.jpg
Size: 53.2 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29464d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchainset_zpsf7a99a32.jpg)
with this chain set i needed to remove some material from the inside of the reluctor wheel and then i bolted and welded the reluctor wheel to the drive gear:
![Name: boltedandwelderreluctorwheel_zpsb4f0e012.jpg
Size: 52.3 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29465d1501275193-1-aweomse-trans-build-pic-heavy-boltedandwelderreluctorwheel_zpsb4f0e012.jpg)
next up is rebuilding the trans: (i skipped pics of installing the clutches)
final drive internal gear:
![Name: finaldriveinternalgear_zps3456844a.jpg
Size: 93.5 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29416d1501275193-1-aweomse-trans-build-pic-heavy-finaldriveinternalgear_zps3456844a.jpg)
roller clutch and forward band:
![Name: rollerclutchandforwardband_zpsda3cc403.jpg
Size: 69.1 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29417d1501275193-1-aweomse-trans-build-pic-heavy-rollerclutchandforwardband_zpsda3cc403.jpg)
driven gear and drum with 1-2 manual band:
![Name: drivengearanddrumwith1-2manualband_zps50b685d7.jpg
Size: 77.4 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29418d1501275193-1-aweomse-trans-build-pic-heavy-drivengearanddrumwith1-2manualband_zps50b685d7.jpg)
reaction carrier:
![Name: reactioncarrier_zps78b4341a.jpg
Size: 79.9 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29419d1501275193-1-aweomse-trans-build-pic-heavy-reactioncarrier_zps78b4341a.jpg)
input carrier:
![Name: inputcarrier_zps13324a64.jpg
Size: 86.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29420d1501275193-1-aweomse-trans-build-pic-heavy-inputcarrier_zps13324a64.jpg)
reverse reaction drum:
![Name: reversereactiondrum_zps74b04812.jpg
Size: 51.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29421d1501275193-1-aweomse-trans-build-pic-heavy-reversereactiondrum_zps74b04812.jpg)
input shaft hub and housing:
![Name: inputshafthubandhousingandreversereactiondrum_zps270322e8.jpg
Size: 68.0 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29422d1501275193-1-aweomse-trans-build-pic-heavy-inputshafthubandhousingandreversereactiondrum_zps270322e8.jpg)
assembly tool needed:
![Name: assemblytool_zpsf4286de4.jpg
Size: 52.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29423d1501275193-1-aweomse-trans-build-pic-heavy-assemblytool_zpsf4286de4.jpg)
![Name: input2nd3rdclutchassembly_zpscb280955.jpg
Size: 75.9 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29424d1501275193-1-aweomse-trans-build-pic-heavy-input2nd3rdclutchassembly_zpscb280955.jpg)
input clutches, 3rd clutches, sprags was just installed with the assembly tool as one unit:
![Name: inputshafthubandhousingandreversereactiondrum_zpsbd2cb140.jpg
Size: 49.7 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29425d1501275193-1-aweomse-trans-build-pic-heavy-inputshafthubandhousingandreversereactiondrum_zpsbd2cb140.jpg)
2nd clutch drum:
![Name: 2ndclutchdrum_zps4ed748b9.jpg
Size: 42.3 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29426d1501275193-1-aweomse-trans-build-pic-heavy-2ndclutchdrum_zps4ed748b9.jpg)
driven sprocket support:
reaction carrier:
input carrier:
2nd clutch drum:
![Name: drivensprocketsupport_zps6ceb0bf4.jpg
Size: 72.7 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29427d1501275193-1-aweomse-trans-build-pic-heavy-drivensprocketsupport_zps6ceb0bf4.jpg)
chain set installed:
![Name: gmr3111inchchainset_zps556ed078.jpg
Size: 79.9 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29402d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchainset_zps556ed078.jpg)
![Name: gmr3111inchchain_zps8a425b8f.jpg
Size: 68.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29403d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchain_zps8a425b8f.jpg)
![Name: gmr3111inchdrivegearwithreluctorwheelwelded_zps8fec935d.jpg
Size: 86.5 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29404d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchdrivegearwithreluctorwheelwelded_zps8fec935d.jpg)
![Name: gmr3111inchchainset_zpsbb0e0b0e.jpg
Size: 58.7 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29405d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchainset_zpsbb0e0b0e.jpg)
4th hub:
![Name: gmr3111inchdrivensprocketwith4thhub_zps2e16d721.jpg
Size: 78.9 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29406d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchdrivensprocketwith4thhub_zps2e16d721.jpg)
4th clutches installed:
![Name: gmr3111inchchainsetwith4thclutches_zpsde060d00.jpg
Size: 94.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29407d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchainsetwith4thclutches_zpsde060d00.jpg)
input shaft and pump shaft installed:
![Name: gmr3111inchdrivesprocketwithaermetinputshaft_zps29d2d8ac.jpg
Size: 71.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29408d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchdrivesprocketwithaermetinputshaft_zps29d2d8ac.jpg)
![Name: gmr3111inchchainsetwith4thclutches_zpsc74a2150.jpg
Size: 57.2 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29409d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchainsetwith4thclutches_zpsc74a2150.jpg)
![Name: 4thclutches_zps39a2f646.jpg
Size: 65.5 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29410d1501275193-1-aweomse-trans-build-pic-heavy-4thclutches_zps39a2f646.jpg)
![Name: gmr3111inchchainsetwith4thclutches_zps1e50e112.jpg
Size: 71.3 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29411d1501275193-1-aweomse-trans-build-pic-heavy-gmr3111inchchainsetwith4thclutches_zps1e50e112.jpg)
now the valve body and channel plate:
![Name: valvebody_zps459bc807.jpg
Size: 75.8 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29412d1501275193-1-aweomse-trans-build-pic-heavy-valvebody_zps459bc807.jpg)
![Name: valvebody_zps78d25b1c.jpg
Size: 56.6 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29413d1501275193-1-aweomse-trans-build-pic-heavy-valvebody_zps78d25b1c.jpg)
![Name: valvebody_zpsb8370c56.jpg
Size: 58.3 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29414d1501275193-1-aweomse-trans-build-pic-heavy-valvebody_zpsb8370c56.jpg)
![Name: valvebody_zpsb91aebeb.jpg
Size: 63.8 KB](https://montecarloforum.com/forum/attachments/engine-transmission-performance-adders-12/29415d1501275193-1-aweomse-trans-build-pic-heavy-valvebody_zpsb91aebeb.jpg)
at this time you would put on the side cover i dont have a pic of that but will update this when i get one.
other upgrades that are done and i did not mention in the write up above, TEP input, 2nd, 3rd clutch upgrades, TEP valve body and channel plate upgrades, ZZP chrome moly pump shaft, cartuning performance 2800 stall converter.
i will be buying a zzp aluminum trans pan to help with heat and also cartuning performance's trans pan spacer to allow more fluid. (pics to come)
i hope you enjoyed looking at some awesome GMR parts and my little adventure through a 4t65-e transmission thanks for taking the time to read and look at all my pics
![Chevy](https://montecarloforum.com/forum/images/smilies/chevy.gif)
EDIT: pics of GMR torsen diff on page 3!!
EDIT: pics of zzp finned aluminum trans pan on page 5!!
4th hub:
![thanks](https://montecarloforum.com/forum/images/smilies/thanks.gif)
Thanks man!!
Chain set I sourced from an individual and they sell for about $1500-$1700 depending on who is selling it etc. Its luck of the draw finding one for sale I got very lucky with the right place at the right time deal to acquire all of this
I might have a lead on a gmr 1" 3.29 ratio chain set if your interested i might be able to get it for you.. If I remember correct he wants $1700 plus shipping...
Thanks man!!
Chain set I sourced from an individual and they sell for about $1500-$1700 depending on who is selling it etc...
Thank you, and I would potentially consider it if I could keep my 2.93 gearing... My car is a street car, and I cruise the highways quite a bit. Not to mention my fuel economy isn't great either.
last time I asked, a 2.93 1" set is roughly 2k... almost as much as my entire trans with the 7/8th chain. So I simply tend to not do burnouts and most of my 'races' are from 40mph roll.
Glad to find another turbo monte...!
Very very nice work your doing there John. I was drooling over all the nice parts your using in your build. Going to be a bad *** tranny that your assembling for sure. Nice clean work, the LSD will be the icing on the cake for this build. Bet you had to sell your soul to find some of those parts. Nice picture presentation you compiled for us all to view. Least we both now will have bad *** trannys and billet limited slip diffs. for our showdown at the 2014 GM Nats...
Congrats on your build!!
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
![Congrats](https://montecarloforum.com/forum/images/smilies/congrats.gif)
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
Wish you a problem free install! Please keep us updated.
John:
That's way to many parts for my brain to comprehend let alone remember where everything goes!![ROTFL](https://montecarloforum.com/forum/images/smilies/lmao.gif)
I'm guessing the toughest part for you is when you take it in and out of the car? Cause it sure looks like you definitely have the inside of the trans figured out!![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
Care to come to Michigan and and "toughen" mine up?![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
Nice job and thanks for shareing!
