'78 drive shaft question
Old Oct 13, 2011 | 11:43 PM
lazyguy's Avatar
Default '78 drive shaft question
I have a '78 MC with 350 engine and TH350 transmission. When I bought the car I didn't get the driveshaft with it. Could anyone give the the length of the driveshaft that should be in there? I got one from a junkyard but it was from an '81 mc and it is too long.
Old Oct 19, 2011 | 04:23 AM
Thrillseeker's Avatar
You can have a drive shaft custom made. Check the yellow pages or internet for a company in your area. You can also have an existing shaft shortenend or lengthened. I had to shorten a shaft when I put a 402 Big block and TH400 in my 77 Monte.
Old Aug 25, 2022 | 10:54 PM
turbojack6's Avatar
Smile Driveshaft Length
I have a 1986 MC with a 406 and TH400 and upgraded 7.5 rear. I need the length for a new driveshaft. Does anyone know the length.
Old Sep 4, 2022 | 09:24 PM
Jeffs02rwdSS's Avatar
Get a tape measure and record the length needed. Most driveline shops will ask for Two measurements. One from the back of the tail shaft (seal area) to the center of the cup on the rear differential and one from the output shaft to the center of the cup.This must be done with it flat on the ground or with jack stands under the rear end.
Rockwood1256
Aug 28, 2019 08:06 AM
crankshaft3rd@yahoo.com
Feb 24, 2012 05:32 PM
AntonGjergjaj
Jul 14, 2009 07:17 AM
jetman4u
May 17, 2009 12:02 PM
bmnsm
Feb 24, 2008 03:37 AM
