Waxing Techniquie
Old Aug 9, 2010 | 02:43 PM
RickAKATed10's Avatar
Photobucket
I think I need to actually buy an orbital. Any suggestions? Links please! lol
Old Aug 9, 2010 | 04:43 PM
jaws2008's Avatar
GOT SPL
Here is a Link to many good orbital and circular buffers (DA and Rotary)
http://www.autogeek.net/bupo.html
I use the Meguiars DA G110v2 and it works great. I use use 6.5" pads and I also purchased a 3.5" backing plate so I can use 4" pads to get on small places.
The Griots is to be a good buffer.
If you can afford it the Flex is to be one of the best around.
Old Aug 9, 2010 | 06:43 PM
silverstreak's Avatar
most of my scratches are too deep to be taken out with a buffer unfortunatly as for the buffer i'm a tool salesman at sears, go craftsman we have some good stuff that might be worth checking out
Old Aug 9, 2010 | 09:26 PM
04FrostSS's Avatar
I can say I have never had a problem with swirl marks with my orbital, although I usually clay bar first then wax after and I use all Mothers products.
Old Aug 9, 2010 | 10:19 PM
SpinEm_90's Avatar
Originally Posted by silverstreak
am i the only one that waxes by hand? some reason it just gives me a sense of accomplishment and it just looks better to me at least
I wax & everything by hand. I spent 6 hours on Friday detailing the monte for the cruise & show this past weekend. It's a good feeling even if your arms are burning lol && it helps keep me in shape to a certain degree
Old Aug 10, 2010 | 06:11 AM
Cowboy6622's Avatar
I usually compound out with a buffer, sometimes I polish by hand, sometimes I use a buffer. I always wax by hand though. The trick I usually use to get a smooth, even coat of wax is to make a single straight line down the middle of a panel you are using, and then move your hand in a circular motion going through the line so that you are constantly distributing wax, and it comes out perfectly even every time!
Old Aug 10, 2010 | 08:09 AM
jaws2008's Avatar
GOT SPL
Back before I started to use a buffer I did it all by hand and I always used the straight line method, and I never worsened the swirls.
To get deep scratches out you can try wet sanding and then use a buffer to get out the sanding marks. Just make sure you always sand in a straight line and keep it very wet, the paint and the sandpaper. Also make sure your sandpaper is wrapped around a pad. You can usually buy kits that will have everything you need.
Old Aug 10, 2010 | 08:46 AM
for the deep scratches/ rock chips i'm going to try the langka product line. you can't see it from my pics but its like my hood has some sort of disease with all the rock chips, makes my heart sink. hopefully that would work out so i have a nice even foinish
East
Jan 18, 2010 09:05 PM
Vailliant402
Sep 10, 2009 12:11 AM
vipermann114
Mar 18, 2007 08:55 PM
Nix_SS
Oct 10, 2006 02:14 AM
Great White North
Aug 23, 2006 07:59 PM
