Removing Pinstripes
Old Sep 21, 2005 | 01:49 PM
KingSize's Avatar
Default Removing Pinstripes
What is a good way to remove the factory pinstripes on an '88 SS??? I tried this with my last Monte using a hair dryer and that failed miserably. I know there's gotta be a way to do this without ruininig the paint. A hair dryer alone isn't going to cut it when removing 15+ year old pinstripes!!!!
Old Sep 21, 2005 | 01:53 PM
montejass's Avatar
Default RE: Removing Pinstripes
I've had success with a mild rubbing compound and a buffer...
Of course I am a detail novice...
Old Sep 21, 2005 | 02:02 PM
KingSize's Avatar
That will take the actual pinstripes off, or just the glue left over?
Old Sep 21, 2005 | 03:04 PM
montejass's Avatar
That will remove everything...... As you noted with the stripes being 15+ years old they are going to be tough. One thing you should be aware of too is that the outline of the pin stripe will more than likely be there after you remove it due to sun fade.
Old Sep 21, 2005 | 05:32 PM
mickey's Avatar
go to eastwood.com and check out thier site they have a decal removal tool out that attaches to a die grinder or a drill and will take them off. they ome in diffrent sizes for diffrent size pin stripes
Old Sep 22, 2005 | 05:57 AM
RIVER RAT's Avatar
3M MAKES A SPRAY ON FOAM THAT I'VE USED IN THE PAST. IT WILL REMOVE THE STRIPES WITH A LITTLE RUBBING AND MAYBE TWO APPLICATIONS FOR THE STUBBORN STRIPES. IT IS CALLED STRIPE AND DECAL REMOVER AND RUNS AROUND $15 A CAN. I HAVE EVEN USED IT ON REMOVING WOODGRAIN PANELS. RR
Old Sep 22, 2005 | 04:29 PM
KingSize's Avatar
ORIGINAL: RIVER RAT
Thanks bro!! Have any idea where I can find this??? Also will it damage the paint of clear?
Old Nov 24, 2005 | 09:07 PM
85_SS's Avatar
I have heard the eraser type tools work well, which is what mickey is referring to. Any detail shop should be able to hook you up. I used a razorblade to remove the decals on my car, but that is very tedious and you have to be careful. Varsol works well from getting rid of the glue residue.
Old Mar 29, 2006 | 01:44 AM
SirMonte34's Avatar
Before the car was mine the owner had it detailed inside and out and whatever they did for a wax job took most of the pinstripe off the sides of the car.........
Old Apr 6, 2006 | 02:05 PM
04MonteLS's Avatar
What worked well for me was a heat gun and AutoMagic
S1knes
Aug 9, 2015 10:11 PM
DeanMachine
Sep 2, 2010 11:06 AM
kissvisions
Apr 26, 2010 11:10 PM
monte97
Mar 29, 2006 05:54 PM
krazy92rs
Apr 5, 2005 04:35 AM
