Light Switch Wiring
Old May 10, 2009 | 03:22 AM
Draciel's Avatar
5 Year Member1 Year Member
Question Light Switch Wiring
I was wondering if anybody could tell me what wires would be best to splice in to for lights to come on when I turn on the gauge lights and what not or if I can just hook up brand new wire some where. I have a 85 Monte.
Old May 10, 2009 | 09:39 AM
The Popcorn King's Avatar
Looking at my old Omega book, you can probably hook up to the Yellow wire (+12V) at the light switch. Don't forget to use a relay to run the lights.
Rule of thumb. Always when with a MM to make sure you are using the correct wire. One thing my teacher told me was that when the cars are being built is that if they would run out of a color wire, they would jsut grab any other color to finish a harness. So double check everything.
looking back, you never mentioned if you wanted to wire in a set of fog lights or what. I'm assuming thats what you are trying to do.
Old May 10, 2009 | 11:04 AM
Draciel's Avatar
No, I'm trying wire a set of interior lights. Sorry about that.
Old May 10, 2009 | 11:11 AM
So you want the lights to come on when you turn on your dash lights?
If thats the case, upi can use the Brown wire (+12V) at the light switch also.
Again, dont forget to use a relay and fuse.
Old May 10, 2009 | 11:32 AM
Draciel's Avatar
Alright so I was thinking an inline fuse set up, what kind of relay do I need to use? Just like a dimmer one?
Old May 10, 2009 | 11:36 AM
YOu can get a relay at any sound shop. BUt if you happen to go at anytime to a pull-a-part junkyard type, then look at the older Toyotas. You can grab a bunch of them from under the hood and put them in your special toolbox. Your pockets(Gee, i wonder why i know that ).
If you need help to wire the relay, let me know. I can post that up too.
Old May 10, 2009 | 11:43 AM
Draciel's Avatar
Lol I go to the self serve junkyard all the time, been there 3 times in the last week haha. But there isn't any specific relay I have to get?
Old May 10, 2009 | 01:19 PM
no. aslong as you see that it has 4 prongs.
hotrodharley
Nov 15, 2013 11:37 AM
tiredvette
Sep 14, 2013 01:03 AM
Harlan2012
Feb 6, 2013 01:39 PM
oh3monteSS
16
Feb 2, 2012 09:11 PM
