engine compartment
Old May 14, 2006 | 02:53 PM
Tony85ss's Avatar
Default engine compartment
Hey I just yanked my 350 out of my 85 SS and I just finished sanding down my engine compartment...now i plan to paint it black, i am wondering if anyone has any suggestions as of to what paint i should use for it. On another note i am also not using my quadrajet intake or heads from my 305, if anyone wants any of them they can make me an offer.
Old May 14, 2006 | 04:52 PM
montejass's Avatar
Default RE: engine compartment
I would play it safe on go with a high temp......
Are you going to base it with a primer?
Old May 14, 2006 | 07:09 PM
Tony85ss's Avatar
yea i was planning on primering and clearcoating it, maybe some rustoleum. But i did pick up a can of high temp engine paint...you think that would be aright?
Old May 14, 2006 | 11:32 PM
montejass's Avatar
ORIGINAL: Tony85ss
High temp would be better IMO.. I tend to over do things so it might be overkill for the firewall.
Old May 15, 2006 | 12:37 AM
Tony85ss's Avatar
aright well thanks for your input...ill send you pics when im done if you want...before/after
take it easy
-Tony
Old May 15, 2006 | 04:47 AM
mickey's Avatar
the best stuff for doing that is RPO-15 high gloss. you can get it threw summit racing and also Eastwood auto.
but the stuff is great, prevents rust from fourming and if there is any rust there ya just sand lightly and paint over it this stuff will kill it and leave a nice finish for ya. also great on frames to so you can paint the upper and lower frame rails on that car and they will hold the test of time. hard to chip and scratch off.
great stuff
as far as Hig temp. yeah i tend to use in on most things under the hood, but really it is not something ya have to do. i do it becuse of headdrers and things of this nature will get hot and could cause other paint to flake or peel if it didnt get a good seal .
Crestview79
Aug 1, 2012 10:46 AM
Monte SSV
28
Aug 23, 2010 09:22 AM
Overdose666
May 12, 2010 06:44 PM
RickCoMatic
Jan 5, 2008 06:30 PM
Mikhal
Jun 27, 2005 04:18 PM
