Dull Nasty Looking Paint
Old May 10, 2009 | 11:17 PM
rpd709's Avatar
Default Dull Nasty Looking Paint
Hey,
Just curious whats the key to success to bringing the shine back into vehicle paint.
My monte has 134,000 Mi on it and the paint is DULL!
Old May 11, 2009 | 08:48 AM
Claybar kit + wax
Old May 11, 2009 | 10:50 AM
sonin66's Avatar
wax is a def, if you leave or park your car out in the sun, you should invest in a car cover to pertect it.
Old May 11, 2009 | 06:39 PM
mrl390's Avatar
If it is really bad, you may need to claybar your car and then buff/polish the paint to get the shine back.
Old May 11, 2009 | 11:31 PM
gothkid's Avatar
ok ok what you need to do is go out and buy meguries color x or meguries ultimate compound....your lookin at 10 dollars....and to achive a glass like finish use a clay bar first. Now you need a real buffer not just a vibrator. After the clay bar use the color x or the Ult Comp, and after that use Meguries Nxt generation wax 2.0.....ta da your car shinny
Old May 12, 2009 | 10:56 AM
RickAKATed10's Avatar
Photobucket
http://meguiarsonline.com/forums/showthread.php?t=88
Seriously, check it out! Great results.
Old May 12, 2009 | 11:42 AM
I'm going to say, if you don't want to spend upwards of 6+ hours on this, and save some money, get a meguiar's clay bar kit from somewhere, I purchased mine at Wal-Mart for $12. It has the claybar, detailer spray, and a liquid wax. Use that, and it should be a lot better than it currently is.
Old May 20, 2009 | 08:17 PM
BLACK ATTACK's Avatar
Photobucket
Monte Of The Month -- December 2007
1. 2000-Grit Wet sand using either a air DA, or Porter Cable 7424 Electrical DA - very light pressure, your goal is just to knock off the high points in the clear coat. WARNING... Hard Pressure or working one spot too long could result in the total removal of clear coat and worse yet, paint...
2. Followed by Meguiars Light Cut = High Density Foam Pad
3. Followed by Meguiars Swirl Remover = Med Density Foam Pad
4. Followed by Meguiars Machine Glaze = Med Density Foam Pad
5. Followed by Meguiars Show Car Wax - Low Density Foam Pad to put on, Clean High Density Pad with a Soft Micro Fiber Bonnet to buff off.
Repeat step 5, multiple times or until paint looks like it is under glass.
Then maintain it with regular washes and weekly waxing.... But that is me...
Old May 23, 2009 | 10:18 AM
skylark65's Avatar
the meguires ultimite compound is amazing stuff, mostly because its easer to apply than waxing the car, and the results are amazing! my dads black 96 ss looked like it was never waxed since it left the dealership, after a good wash we used the meguires compound, 2 coats, and a coat of wax, the color & shine came right back, it looks like a different car! ( still no where as nice as black attacks, though, lol) i dont know how bad your car is, but i would definitly reccomed the meguires.
S.O.G.
Jul 6, 2012 06:09 PM
jack340
Jun 28, 2012 01:08 PM
red04montels
Mar 21, 2011 10:28 PM
jeffsmonte
Oct 5, 2010 10:18 PM
wht02monte
May 17, 2010 08:48 AM
