Low Trac Light and dull ticking help!!!
Old Jun 28, 2012 | 12:43 PM
jack340's Avatar
Default Low Trac Light and dull ticking help!!!
I have a 1997 Monte Carlo z34 that i just put a bone yard ABS motor and master cylinder in. It works fine and everything is bled out but when i reach 25 mph or higher as i step on the breaks there is a dull ticking that gets faster the more the car slows down and the low trac light comes on and it sounds like the ABS motor engages. Also it feels like the brake booster is a little loose if that could cause it. CAN ANYONE PLEASE HELP!
Old Jun 28, 2012 | 12:50 PM
Said you got it from the boneyard...
Did you get it off a wreck?
If so, maybe its defective as well?
Something to consider...
Old Jun 28, 2012 | 01:02 PM
jack340's Avatar
Im not sure it was from ebay. Could the wheel speed sensors do it? The right front seemed to be glitching on the tech 2 data display
Old Jun 28, 2012 | 01:08 PM
Try replaceing it....
and see if the "data" goes away for sure.
Cant hurt.
matthew41
Jan 25, 2015 11:22 AM
vincenti
Oct 28, 2014 09:04 PM
ladagosta
Aug 24, 2012 09:54 AM
Monteimpala
Mar 8, 2012 02:32 PM
jonlberg109
Jun 27, 2009 09:24 PM
