Caliper painting
Old Nov 29, 2007 | 08:46 AM
rchurch's Avatar
Default RE: Caliper painting
I did mine 2 years ago when I installed drilled rotors, ceramic pads and stainless lines. Of course I had to take the rotors off to do all that. I cleaned the calipers with brake cleaner, hit them with a wire brush, cleaned them again, and used hi temp paint. I used several cans of brake cleaner, and 2 cans of paint and put 2 coats on each caliper, the first one a light coat and the secondmuch heavier. After 2 years they still look good, but are stained causing them to not be as bright looking, which I think is normal. I have wiped them clean before with some brake cleaner, but stopped because it took some paint off. You can look at a pic in my profile. BTW - the lug nut cover on one of my rims came off while I was drivingand I lost it, and now they tell me the wheels are discontinued so I can't get a replacement. SUX!!!!
Old Nov 29, 2007 | 08:48 AM
rchurch's Avatar
montejass - good to see you here! Been a while!
dbaldwin
Oct 7, 2013 12:12 PM
iMuf
Jun 24, 2013 08:21 PM
Boxman420
Jul 3, 2011 02:40 PM
spavo
Nov 13, 2005 12:38 PM
kissmyss03
Jun 27, 2005 03:46 AM
