California Car Duster
Old Apr 7, 2015 | 03:02 PM
tweek's Avatar
yeah I usually use a leaf blower to dry my car then Ill go over it with detail spray
Old Apr 7, 2015 | 03:09 PM
My CA duster is machine washable - I toss it in the washer every so often
Old Apr 7, 2015 | 04:51 PM
Talking
Originally Posted by tweek
Ok so it seems like a lot of us have used the California Duster. Has anyone used the drying blade made by them?
There are a couple of different styles of the wiping blade. I have one and love it, But if you look at the blade it is T-shaped at the end where you move the water. this is the softer silicon one and it is very flexible and works.
Old Apr 7, 2015 | 04:55 PM
Talking
Looks like this one check the link.
Soft Silicone Car Auto Flexible Wash Brush Cleaner Wiper Squeegee Drying Blade | eBay
Old Apr 7, 2015 | 07:59 PM
xxtheshockerxx's Avatar
RED DEVIL
I won't use them. I have a detail shop and you see alot of the "show" guys using them that bring their cars in that end up scratching them all up and I have to buff out. Usually if my car is dusty enough to need wiping I just wash it and that prevents dragging dust and whatever all over. Otherwise it's microfibers and a good spray wax.
Old Apr 7, 2015 | 11:36 PM
Always have the Calif. duster in the trunk. I just beat it on the fence or storage bld walls to knock off the excess dust. I too use the water blade to help reduce the drying time removes 80% of the water and then drying is pretty quick from there.
You should dust off your car before putting the cover on it. That way dust particles are not trapped under the cover and when the wind blows the cover about your not chaffing the car's paint. And your car cover will be clean and not have dust adhered to it's underside and then getting on and scratching up the cars paint when you put it back on. You should also dust off your car cover before removing it so when you roll it up and fold it your not getting dust all trapped on the reverse of the cover again.
LOL, so simple and so many little things to stay on top off.
It's nice your moving your car care skills up to the next level and doing the car cover and Calif. duster routine, it's going to make your maintenance much simpler.
Old Apr 8, 2015 | 08:55 PM
I use a California duster, but I use it lightly. Never use a lot of pressure or you will get scratches.
Old Apr 9, 2015 | 06:36 AM
Must be pretty sweet to pick one up for $12. They are like $30 here. Even the dash duster is $20.
I have both and I replace it annually
Old Apr 9, 2015 | 10:11 AM
X2.... you never want to bear down on the duster very light touch and I shake mine out after each sweep
nascar43
May 8, 2012 09:12 PM
Barovelli
Aug 25, 2011 07:29 PM
aamer415
May 11, 2011 08:50 PM
fadedfutures
Nov 23, 2009 01:17 AM
SoCalSS
Oct 5, 2006 10:09 PM
