Best wax for a black Monte?
Old Jul 4, 2009 | 06:58 AM
RocknSS04's Avatar
Default Best wax for a black Monte?
So I'm TIRED of scraping all the white residue from all the little cracks and crevaces around all the trim and emblems. Ther MUST be something other than white wax that is just as good. I've tried Turtle Wax Ice, and I like the stuff, but there is no long lasting durability to it. I'm a Meguires NXT fan, but I'm tired of the residue.
HELP!!!!! What do all of the other MCF family member use to wax your BLACK Montes????
Old Jul 4, 2009 | 07:12 AM
I don't know how I double posted...Sorry....I must get some rest : )
Maybe it was from watching the vid's contained on my 2nd post below link : )
WoW
http://www.zainostore.com/
Above link is what many of the affluent customer's
use on their expensive cars.
It's amaz'in on BLACK 4-Sure.
Check out there site.
Old Jul 4, 2009 | 07:27 AM
Hi Wayne,
I don't know `if this is the best, but it's what worked for me
on my Black Honda
I would first clay bar & then apply the below product.
*Check Vid's out of Girls applying Liquid Glass : )
Even `if U don't use the Liquid, the Vid's are
borderline X-Rated Entertaining 4-Sure
I also love Eagle One Detailer, in between Liquid Glass.
It will be interesting to see what member's post.
We have several Member's that are pro Detailers
and I look forward to seeing what they post.
Good Luck
Black is beautiful, but takes extra care
4-Sure
Old Jul 4, 2009 | 10:29 AM
Well Wayne, when I owned my Black Mini, I used Meguires NXT 2.0 liquid wax and I applied it with my Porter Cable orbital buffer, and I didn't get a lot of white residue. I also found that the NXT wax was pretty easy to take off with a microfiber cloth.
Old Jul 4, 2009 | 11:32 AM
Enzo354's Avatar
STILL SLOW
I use a microfiber cloth too, but I know what you mean by the reside. It gets stuck around the badges and on the window moldings. And you cant see it till after you wash it for the first time after you wax.
Old Jul 4, 2009 | 11:48 AM
ChevySSGirl's Avatar
wayne, i've been using the meguiar's NXT also, and the quick detailer in between waxing. try a q-tip to get the crud out. i have some too once in a while, mine is usually in the thin openings where the panels meet.
Old Jul 4, 2009 | 12:07 PM
Whatever Member Rich Post..., I would do
`amen
Old Jul 4, 2009 | 12:18 PM
04MonteLS's Avatar
`amen
As always, thanks for the cosign!
S100, found at your local Harley Davidson dealership, is what you want. You get no residue, can layer it for additional depth and gloss, is about as easy to apply and remove as there is (even if you let it sit on the paint for 2hrs, it's still just as easy to remove as doing so right away) and it's durable. Also, it doesn't stain plastic/rubber trim and can be used, with awesome results, on your glass as well. It's probably the best $16 you'll spend for your car.
Old Jul 4, 2009 | 12:25 PM
Your Welcome `Rich,
I've seen your B-4 & after pic's on the awesome work
that you are doing on auto's / trucks etc.
Thanks for sharing/posting.
Great to see you online.
Happy 4th to you & family.
Below are some links
<LI class=g>S100 Carnauba Wax
S100 Carnauba Wax for motorcycles is hand formulated with the same care as the P21S paste wax. ... S100 Carnauba Wax is a hand-poured blend of German waxes, ...
www.topoftheline.com/s100motorcyclewax.html - Cached - Similar
<LI class=g>Shopping results for s100 wax
S100 Carnauba Paste Wax $15.95 - AutoBarn.com S100 Carnauba Wax $16.99 - Latus Motors Harley ... S100 Canauba Paste Wax $13.90 - FastCycleParts.com<LI class=g>S100 Carnauba Wax is a hand-poured blend of German waxes ...
S100 Carnauba Paste Wax - Gives a great shine in very little time! This paste wax applies as easily as a liquid. The chemists at S100 searched from the ...
www.autogeek.net/s1capawax.html - Cached - Similar
Old Jul 5, 2009 | 07:02 AM
RocknSS04's Avatar
Thanks all for the tips. We've been using Meguires NXT and the Quick Detailer for quite a while. Just seems like the residue keeps coming back. Nice shine, and durable, but it is NOT friendly on the rubber trim and plastic. I want something either clear or black. No more white wax for me. Are all of the waxes recommended either clear or black?
