~ Simple Solutions ~
Below is one product by RainX for fogging.
7oz for 4.99
Hope it helps. I have never used the fog, but have used RainX for windows
and it does a decent job during tropicial storms here in FLorida.
![](http://www.theconsumerlink.com/imagesEdp/RainX/p40574b.jpg)
[ul][*]Rain-X® Anti-FogTM eliminates and prevents fogging of interior glass and mirrors[*]Aerosol format delivers a more precise amount of Rain-X® Anti-FogTM to a specific location than the liquid bottle format [/ul]
i don't suppose there is something to use on the inside of windshields to prevent (or reduce) fogging on summer nights? i was driving the interstate the other night and had to choose between keeping cool or keeping the windshield clear (too loud to keep the windows open at 75+). if only the A/C controls had a defrost/face setting (like the feet/face combo)...
Turn the heat up on the A/C setting a little.
With the inside air of the car being so much cooler then the outside air, you're getting fog on the windshield.
By just turning the heat setting up a little it will help eliminate the fogging.
You don't need to turn the heat up enough to burn you out.
A small amount is all that's needed.
You're trying to offest the affects of cool air coming in to contact with warm air. Which is what's happening on your windshield.
actually, i tried the rain-x product kidd found and it worked... the only problem is that i am still learning how to properly apply it and it left a little bit of a streak on the windshield. i will have that issue worked out early next summer when i start using it again.
the problem with running the heat is that i can't stand stale air... in order to puch the right temperature of air onto the windshield, i have to use the defrost setting. when you use that in an '04, you have to switch off the air feed to your face. i don't know why our controls don't have a "Max" setting like a lot of older GMs (particularly the Blazer/Suburban/vans) but they don't... it runs from defrost to defrost and feet to feet and face to face... and i just can't stand to not have air moving past my face (a mental motion sickness issue... the air flow i feel has to match, or reflect, the rate of travel). it's not a hot/cold thing... it's an air-flow thing, but thanks anyway!
Repair Guide: List of Common Monte Carlo Problems and Solutions
ChibiBlackSheep
FWD Tech Guides '95-'07
92
03-20-2014 10:38 AM
6th Gen ('00-'05): Exhaust issues and solutions?
bowtiebandit23
05-10-2013 12:01 PM
BeachBumMike
07-04-2007 12:08 PM
dogmanx
11-26-2006 06:11 PM
