suggested tire pressure
Old 01-23-2011, 10:26 PM
Originally Posted by supercharged05ss
i check them warm and set a 40 psi warm.
what does your door panel say about psi? I think 40 psi is way to much for a recommended tire pressure!
Old 01-25-2011, 10:35 AM
I run 35 psi Michelin hydroedge tires. At 3.00 a gallon for gas a little less comfort is ok. Since tire installation I have seen a 1/2 to 1 mpg increase.
Old 01-30-2011, 12:39 AM
the previous owner tried to remove the tire psi label,i guess,it is unreadable since i bought the car.been running 40 psi warm for 4 years no issues with tire wear,got 111,xxx miles on the car and i bought it with 8k and i have only bought one set of tires at 65,xxx to replace the factory goodyear eagle rs-a tires it came with.btw,the tirerack says you must use a 225/55r17 with a 17x7 inch wheel,is this true,factory size for my car is 17x6.5 with a 235/55r17 tire,discount tire direct does not make the same claim and i do not want to get 17x7 wheels and new tires that do not fit.
Old 01-30-2011, 10:28 AM
Cowboy6622's Avatar
I just keep them between 30 and 35 myself.
Old 01-30-2011, 11:01 AM
This, I try to maintain it at 35, but won't panic if it gets down to 30
either.
joe111599
06-10-2016 07:01 PM
Randy Biron
07-14-2012 08:07 PM
big green dog
03-14-2012 02:56 PM
Greeny
10-30-2006 11:50 PM
keghead40
07-19-2005 12:13 AM
Quick Reply: suggested tire pressure
