Sunroof Sticking
Old Apr 2, 2013 | 08:18 PM
Jethro's Avatar
Default Sunroof Sticking
Hey guys, I had the sunroof replaced about 3 weeks ago. It was used sunroof but it worked properly. I am having an issue where when you tell it to open, it will open upwards like it should, then when you hit it again to go back it only moves about 2-3 inches. Motor is fine and track is fine as well! I invested a slight bit and wondered if the tracks on the inside were supposed to look like this or if it is build up and blockage stopping the sunroof from going completely back.
Far it Opens:
Track Condition:
As you can see it looks like it has some build up. Opinions or fixes anyone?
Your time is greatly appreciated, thank you!
Cody
Old Apr 2, 2013 | 08:41 PM
owens91's Avatar
im curious on this because mines looks the same except it has grease in it, and it sticks at times as well...hmmmm
Old Apr 2, 2013 | 08:48 PM
Jethro's Avatar
Well mine doesn't really open all the way at all, did it once then started only doing it a couple inches. But hey it closes and seals and keeps water out which is biggest thing for me.
Old Apr 3, 2013 | 06:36 AM
03SSLE's Avatar
I think I would start by cleaning and lubing the tracks. No offense, but those things are filthy! Getting all the dirt out of there and some fresh lube may be all it needs.
Old Apr 3, 2013 | 06:49 AM
I would try to use wd40 to clean those tracks out but don't get it on your headliner. Use white lithium grease once it is clean to lube the tracks
Old Apr 3, 2013 | 03:27 PM
Jethro's Avatar
None taken, I feel kind of stupid for not thinking to clean them out but I figured when i purchased it would be sent to me in good working order!
Alright will do! I have a can of W-40 already, will need to go buy a very firm toothbrush and clean that out. Is white lithium grease something that I can find at say oreilleys or Autozone? or will it need to be purchased online?
Old Apr 3, 2013 | 05:15 PM
Oreilys has the grease you need. It comes.also in an aerosol can with a directional tube to spray/lube with accuracy
Old Apr 3, 2013 | 11:22 PM
Jethro's Avatar
Alright thanks mate! I will look for that one, seems like it would be a bit easier!
Old May 2, 2013 | 09:29 AM
bowtiebandit23's Avatar
mine used to shake/jump when opeing it, never had a problem with closing. cleaning some gunk out with a small scraper and then sprayed a light coat of cooking spray PAM and havent had a problem since
Old May 3, 2013 | 06:34 AM
butch049's Avatar
Default Mine stuck
Mine stuck at first opend a little. Move switch back and fourth finally opend cleaned and greased works great now.
ladyvyxen
Jan 14, 2013 08:28 AM
jay26
Dec 8, 2007 08:27 AM
ckerdflag
Jun 1, 2007 09:59 AM
jogasz28
Jan 28, 2007 01:02 PM
Visual7
Aug 29, 2006 08:50 PM
