Quickest 3100 removal method
Old 08-09-2013, 10:53 AM
trimntim's Avatar
Awaiting Email Confirmation
Default Quickest 3100 removal method
What is the quickest and easiest way to pull a 3100 from 96 monte
Old 08-11-2013, 01:28 AM
I don't know about a 3100 but for a 3.4 V6 DOHC I have read that the easiest way is to raise the vehicle, disconnect the subframe and lower it from the bottom. But that seems like non-sensible advice to give on do-it-yourself forums because it should seem obvious that people do not have a mechanics shop at home with hydraulic car lifts in their garage.... If you have an engine hoist it maybe possible to lift your 3100 out of the car from the top with the transmission attached. It is doable with the 3.4 V6 DOHC.
Enzo354
09-13-2009 12:15 PM
seanzyyy
04-21-2009 04:14 PM
odessadude
30
12-21-2007 03:14 PM
BeachBumMike
07-16-2007 12:39 AM
Quick Reply: Quickest 3100 removal method
