Key fob
Old 11-02-2006, 09:36 AM
ffej06montess's Avatar
Default Key fob
My key fob needs to be recoded, does anyone have any idea how to do this??
Old 11-02-2006, 05:10 PM
GrandPaDave's Avatar
Default RE: Key fob
The owner's manual says to see your dealer, but we all know how costly that can be
Old 11-02-2006, 07:27 PM
Default RE: Key fob
na they will do it for free its pretty simple
Old 11-06-2006, 08:30 AM
Default RE: Key fob
These instructions should work.
1. Turn the ignition to ACC or ON and the radio to off. Do not crank the engine.
2. Press and hold the DISP button on the radio for at least five seconds until settings is displayed.
3. Press the SEEK up or down arrows until FOB PROG appears on the display.
4. Press the PREV or NEXT button to enter the submenu. The current selection will have an asterisk next to it. BEGIN will be displayed.
5. Press the DISP button to start programming. When the message PUSH FOG flashes, press and hold the LOCK and UNLOCK buttons on the first transmitter at the same time for 15 seconds. A chime will be heard to verify the transmitter is learned.
6. Repeat Step 5 for each additional transmitter up to four remotes total. You do not need to press the DISP button again, just press down the LOCK and UNLOCK buttons on the next transmitter to be learned to a maximum of four transmitters per vehicle.
The mode you selected is now set. You can either exit the programming mode by following the instructions later in this section or program the next feature available on your vehicle.
EXIT (Exit Feature Customization Mode): This feature allows you to exit the vehicle customization programming.
To Exit:
1. Scroll until EXIT appears on the display.
2. Press the DISP button to exit programming. A chime will he heard to verify the exit.
Old 11-14-2006, 10:19 AM
Default RE: Key fob
nope - those won't work... it's different for an '06... Our stuff is in the DIC and with separate menu settings/buttons, not in the radio at all.
Look in the owner's manual, it'll tell ya... in the DIC, while you're in Park, one of the settings in the setup menu is to "Relearn Keyless Remote" - or something like that. Then it's just a couple clicks from there and you should be all set. Like I said, read the owner's manual for exact steps, as I haven't had to do this - but I know the option to do it is in the DIC setup menu as I mentioned.
Old 09-26-2010, 12:23 AM
thanks for the help
Old 12-14-2010, 09:00 PM
anyone knows how to program a key fob from another car to work with my car? i tried doing it through the stereo but i didn't get the chime/beep that my original key fob does, is it possible to program a new key fob programed to a different car into mine?
Old 12-16-2010, 10:01 AM
probably would of been beneficial to of put this in the 7th gen section
jeffrae
02-27-2008 10:52 PM
ffej06montess
06-05-2007 11:29 AM
Datafive0
03-12-2007 02:29 PM
ralphtrent
12-24-2005 01:01 PM
03SSdriver
09-16-2005 10:43 AM
Quick Reply: Key fob
