crankshaft position sensor, 2000 MonteCarlo 3.8L
Old 03-21-2006, 04:15 PM
erik2282's Avatar
Default crankshaft position sensor, 2000 MonteCarlo 3.8L
I'm wanting to change the crankshaft position sensor on my brothers 2000 monte carlo 3.8L. It looks like you have to remove the crankshaft pulley, but it wont come off with my 3/8" impact. Like the bolt is on there too tight. Does anyone know a trick to remove the pulley? Do I even have to remove the pulley to replace the sensor? one more question, when I replace the sensor do I have to replace the sensor gause also?,as it is two different parts.
Thanks for reading. I appreciate all comments and responses, thanks again...
Erik
Old 03-21-2006, 05:04 PM
Default RE: crankshaft position sensor, 2000 MonteCarlo 3.8L
Unless you have a high dollar Snap On or Matco airgun your 3/8 don't have enough grunt. My 1/2" Craftsman pops them off.
Old 03-22-2006, 10:09 PM
erik2282's Avatar
sorry, I meant 1/2" impact, not 3/8s, it's a ingersoll. still wont come loose. someone on another site told me that to replace the sensor, you have to use some kind of special alignment tool for the sensor. anyone know anything about this...
Old 04-21-2006, 08:17 PM
erik2282's Avatar
I got the bitch-*** bolt to come out. Now the problem I am having is puling out the crank pulley(harmonic balancer). The bolt is out but the balancer wont come out. I rented a puller from the auto parts place and it still wont come out. I'm about to put a come-along on it and pull that *****, hopefully that'll work
Old 04-27-2009, 04:32 PM
I'm having this same problem. I wonder if he ever got it out. The bolt is out but the pulley is stuck.
Franks 03SS
14
12-27-2021 08:05 PM
philly94ss
22
11-07-2011 02:27 PM
robwofter
08-10-2011 10:33 PM
motivation2k3
09-04-2008 07:15 AM
jet404
08-22-2005 12:51 AM
Quick Reply: crankshaft position sensor, 2000 MonteCarlo 3.8L
