5 1/4 or 6x9 for rear deck.
I just bought a 06 lt with factory system with no amp. I am looking at cruchfield and thinking of putting Boston acoustics pro50 se 5 1/4 components in the doors but have no idea what to do with the back. My plan is to use a Boston acoustics gta-704 amp to run all 4 speakers as it has speaker level inputs and 70 wats rms x4 at 4ohms or 125 wats rms x4 at 2 ohms. should i just use the ba pro50 se speakers in the rear deck as well? i do plan on putting a sub in at some point like a single 10 or two 8's it wont happen for a while tho. any ideas or recommendations i would like to stay in the $200 range for the rear deck as i will be buying in stages.
Ok, and will 6 1/2 fit in the door? If so i know exactly what set up ima use.
A guy on here did put them in but his required modification. He Cut and fiber-glassed the door cards. I think it depends on how deep they are. My 6x9 lasted 2+ years but the speakers lost thier thump. Kept mid and high but the bass fell out compared to when they were new.
6.5's will bolt right in and require no modification so long as the depth of the driver is not too much.
stratonx
FWD Tech Guides '95-'07
07-18-2012 02:42 PM
Bxbootlegger
02-14-2008 08:34 PM
