aftermark radio still sounds bad!
Old Aug 8, 2012 | 09:15 PM
sickmontesson2s's Avatar
Default aftermark radio still sounds bad!
Can anyone help me figure out if i'm using the wrong harness! I just recently replaced my factory radio with the JVC av60 but wishing i never upraded because of the low volume and distorted speakers! The car is a 2002 ss w/onstar factory amp no Bose, the local shop told me that my car called for the GMOS-04 harness but doing some research i think they might be wrong! I'm thinking the correct harness is the GMOS-01 or GMRC-01. ( i'm i correct or not)??????... please help
Old Aug 8, 2012 | 09:43 PM
The GMOS-04 is correct, although there are some cheaper options that you could have gone with.
Product Features
-Compatible with amplified GM vehicles
-For amplified audio systems premium and Bose
-Retains OnStar with adjustable volume output
-Retains chime with adjustable volume output
-Retains RAP feature
-OnStar Interface for Amplified GM Systems
-Interface designed to allow for the replacement of the OEM Radio with an aftermarket unit in amplified GM Vehicles with Premium or Bose audio systems.
-Compatible with the following vehicle:
Buick: 2005 - 2007
Allure.2004 - 2005
Century. 2005 - 2007
LaCrosse. 2004 - 2007
Rainer. 2002 - 2007
Rendezvous. 2005 - 2007
Terraza.Chevrolet:2003 - 2006
Avalanche.2000 - 2005
Cavalier.2005 - 2007
Corvette.2003 - 2007
Express.2000 - 2005
Impala.2002 - 2003
Malibu.2000 - 2005
Monte Carlo. 2003 - 2006
Silverado. 2003 - 2006
SSR. 2003 - 2006
Are you on the stock speakers? Do you know if they are being powered by the stock amp still? You may want to look into bypassing the stock amp to run the speakers off the amplifier in the JVC headunit.
This can be done by removing the amp and replacing this in it's place:
METRA 70-2054 GM MULTI 1998-2008 AMP BYPASS HARNESS FOR AFTERMARKET INSTALLATION | eBay
Or if you're good with wiring you can cut and splice the wires together, but then you would have to cut the stock wiring harness and clip out.
Good luck, post if you need more info
Old Aug 8, 2012 | 10:15 PM
Yes i'm using the stock speakers and they r being powered by the fac amp! do u think the harness is bad or if i bypass the amp will i still have good sound?
Old Aug 8, 2012 | 10:17 PM
Ive never seen anything like this before! GM really got me in a bad place with this 1!.....smh
Old Aug 9, 2012 | 05:03 AM
z34man's Avatar
hi their im new to the site but i use to have a 00 model and had to deal with the same things the aftermarket kit ran me $100 bucks but in order to even lessen to your after market jvc you are going to have to bypass the factory amp check the wiring your installer did and make sure all wires are not crossed around and were they should be it took me and my installer about a hour when i had mine to even get it working right im surprised ur even aboul to here more then a whisper from them with the amp still active also but dont hold me to it if i remember right because it was like 2yrs or so ago it should also deactivate the door chime but im not 100% sure on that i think the model i had deactivated mine
also not 100% on but u loose your controls to the computer when you took out the factory radio because everything on in your dash oil lights and all are controlled threw the radio but like i said its been a while sense i had the car so im sure their has been a lot of updates for the systems to still control the computer settings
Old Aug 11, 2012 | 01:02 AM
Milhouse's Avatar
That's the problem...stock speakers and powered by factory amp. IMO, it kind of defeats the purpose of upgrading the deck if you're gonna keep the factory speakers and run them off the stock deck because the main benefit of the upgrade is the increased sound quality that comes along with it. The factory speakers leave much to be desired in the SQ area and the factory amp puts out about as much power as most decks nowadays and attenuates the bass output at higher volumes as well.
My suggestion would be to bypass the factory amp, upgrade your factory speakers to aftermarket 4ohm models and enjoy the new, great sounding setup you have.
Old Aug 11, 2012 | 02:57 PM
Murray137's Avatar
im running an aftermarket deck with stock speakers in my ss and sounds perfectly fine. have much more control of the sound quality with the new deck and makes the bass 10x louder
Old Aug 11, 2012 | 03:00 PM
Just bypassing the amp will probably satisfy your needs also
Old Aug 11, 2012 | 03:17 PM
walkingonabullet's Avatar
have you considered a broken amp? maybe your problems were in your amp from the beginning. these cars dont really have disapointing stock systems even with out the boss system.
Old Aug 11, 2012 | 09:54 PM
Milhouse's Avatar
That's quite the exaggeration there, but it certainly improves the overall SQ noticeably
