Top Speed
Old 04-22-2009, 07:34 PM
McMan's Avatar
Default Top Speed
Whats the top speed of a 2004 monte supercharged?
Old 04-22-2009, 07:54 PM
if you have the car, try it out and let us know!
Old 04-22-2009, 08:21 PM
McMan's Avatar
I dont though YET
Old 04-23-2009, 08:02 AM
don't those speedo's go up to 140MPH? I know the Monte in the upper left of your screen by the Monte Carlo Forum banner does (I don't know what year it is). I did a little math a while ago and figured if you let your Monte upshift into overdrive, and you don't have a limiter, and can feather the accelerator until you reach 6000RPM, and not kick back down into passing gear, you should be able to reach around 160MPH, unless the gearing prohibits it. I know there's a lot of "if's" and "ands" in there. whaddayagonna do.
Old 04-23-2009, 09:41 AM
RickAKATed10's Avatar
Photobucket
Any particular reason why it matters? I'm just curious. If you can't take it on the Autoban it really doesn't matter if it can go over 90 MPH. Unless, of course, you intend on racing it.
Old 04-23-2009, 02:53 PM
Fast enough. My LS with speed limiter will go ~110mph and my friend's SS N/A with no speed limiter maxed out the stock speedo.
Old 04-24-2009, 06:29 AM
RocknSS04's Avatar
Speed limiter is set to 125. It holds 125 easily. I've had mine to 135 a couple of times on the freeway. Next time I'm going to peg the speedo, I KNOW it will.
Old 04-25-2009, 12:37 AM
nemesis's Avatar
2009 Monte Of The Year
when mine was stock i think it max out between 115-120 mph
MyIntimidator
12-21-2010 05:54 AM
BeachBumMike
02-27-2008 07:24 PM
ajsbengals
15
10-07-2007 09:37 AM
Yellow_Monte
06-16-2006 12:26 PM
Quick Reply: Top Speed
