double timing vs stock timing chain
Old 05-22-2013, 06:09 PM
Dam20735's Avatar
Default double timing vs stock timing chain
im having problems with my double timing chain an setting the timing so until i get a new zzp double roller master can i use the stock timing until then an if i do what will happen with my s1x cam?
Old 05-23-2013, 08:46 AM
turbo monte's Avatar
Nothing will happen to it but the chain could break (doubtful) and if it breaks say good bye to your whole engine.
Old 05-23-2013, 09:34 AM
Also if it was me I would be pulling heads and making sure nothing made contact and broke when you were running the engine out of time. Valves were open at the wrong time and could of hit the pistons. Could of bent valves, pushrods etc. I would definitely be inspecting all of this before I tried starting it again. Just my .02
Old 05-23-2013, 04:09 PM
x2 on what turbo monte said. I wouldn't recommend driving it with the stock chain
Dam20735
06-03-2013 07:45 AM
Dam20735
05-19-2013 05:32 PM
frosty5011
12-01-2007 03:47 PM
fedspunisher
11-12-2006 06:52 PM
Quick Reply: double timing vs stock timing chain
