double timing vs stock timing chain
Old May 22, 2013 | 06:09 PM
Dam20735's Avatar
Default double timing vs stock timing chain
im having problems with my double timing chain an setting the timing so until i get a new zzp double roller master can i use the stock timing until then an if i do what will happen with my s1x cam?
Old May 23, 2013 | 08:46 AM
turbo monte's Avatar
Nothing will happen to it but the chain could break (doubtful) and if it breaks say good bye to your whole engine.
Old May 23, 2013 | 09:34 AM
Also if it was me I would be pulling heads and making sure nothing made contact and broke when you were running the engine out of time. Valves were open at the wrong time and could of hit the pistons. Could of bent valves, pushrods etc. I would definitely be inspecting all of this before I tried starting it again. Just my .02
Old May 23, 2013 | 04:09 PM
S.O.G.'s Avatar
x2 on what turbo monte said. I wouldn't recommend driving it with the stock chain
Dam20735
Jun 3, 2013 07:45 AM
Dam20735
May 19, 2013 05:32 PM
frosty5011
Dec 1, 2007 03:47 PM
fedspunisher
Nov 12, 2006 06:52 PM
