Which Intake Manifold is Better (1974 400 small block)
Old 10-31-2010, 05:12 PM
Visceron's Avatar
Default Which Intake Manifold is Better (1974 400 small block)
I have a friend who is giving me a Edelbrock 2116 performer intake manifold. I wanted to know if I should use the 2116 or keep the C3BX that I have on it right now. Everything works fine with my 625 cfm Carburetor. I dont know if this will work with it if I do the swap though.
Old 10-31-2010, 06:59 PM
Unless you have votec heads that intake will not work.
Old 11-01-2010, 01:16 AM
Visceron's Avatar
The intake looks almost exactly like the one I have. Isnt Vortec for the newer Chevy engines? I have a 400 V8-Turbo Fire.
Old 11-01-2010, 09:56 AM
yes the vortec heads are off new chevy engines..i believe 96+ until they switched to the LSx style.
that 2116 is for vortec heads, and will not work properly if you do not have them. im assuming you do not because of the fact that you are using an old c3bx manifold..
bbyblue74
07-16-2023 12:16 PM
11-02-2014 05:22 AM
wht02monte
04-26-2010 08:28 PM
johnmxh
10-05-2009 05:07 PM
BeachBumMike
04-07-2008 08:39 AM
Quick Reply: Which Intake Manifold is Better (1974 400 small block)
