Random Cylinder Misfire and Air Pump Check Engine Lights
So Ive been having a lot of issues with the MC recently. The most recent was a check engine light which I had scanned as a Random Cylinder Misfire and another for the Air Pump failure (blows fuses). My engine bogs down hardcore and I have absolutely no acceleration when driving. Its been getting worse so now I'm starting to worry. Im thinking its an air intake issue, possibly the intake manifold? I checked the air filter, its not the cleanest thing but its definitely not hindering airflow too much. Does anyone have any ideas on what I should check? Thanks in advance!
The second is P0410: 'Secondary air injection system fault"
Very grateful for any input anyone has in this matter.
If I were you, I would check all of the spark plugs real quick and see what they look like, but you really need to have a compression test run on your Monte. Let us know what happens after that.
Sounded either like sucking air or the air pump eating it so I checked the engine today while changing my brakes and serpentine belt (which is a total PIA, there is no way that the tensioner should be at full extension and barely able to get the belt on). All spark plugs in perfect condition, but the upper intake manifold appears to have NO gasket. I heard a whisting (low pitch) today while accellerating so I thought I had an air leak somewhere. Turns out its spotty all around over the manifold. Guess Ill be pulling that off tomorrow after work. Anyone know if this is a tough job? Seems like a ton of wires and such on top that I have to take off before I can get the manifold off. TIA
6th Gen ('00-'05): help... check engine code cylinder 2 misfire
Kandyce
11-23-2014 08:27 AM
05montecarloyo
08-08-2012 07:02 PM
spersavage
11-01-2009 11:31 AM
menaja19
14
01-02-2008 09:21 PM
