oxygen sensor problem
Old 01-08-2008, 08:50 AM
splendidkiller's Avatar
Default oxygen sensor problem
ok, i have a 2001 monte carlo ls. my engine light keeps comin on and when i read it with the obd2 reader it gives me a code of 0420. which is something to do with my catalytic converters or my oxygen sensors. i had it checked out before and was told that it was the aftermarket catalytic converter placed on the car a little back and it would always mess with the oxygen readings on the O2 sensors. i don't know if this is true or not, but it's costing me in gas and i need to find a cheap fix for this... any ideas?
Old 01-08-2008, 09:18 AM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
Default RE: oxygen sensor problem
That's a cat code, O2 sensor should throw an O2 sensor code. I've heard that the aftermarkets cause this problem A LOT.
Old 01-08-2008, 05:01 PM
X2
The aftermarket cats will throw the P420 code roughly 500 - 1500 miles.
Just get a hand held scanner that can delete it and throw it in the center console to clear it.
Old 06-04-2008, 11:20 AM
hey when you figure this out let me know. my 96 is doing the same thing.
Old 06-04-2008, 12:47 PM
Or check your EGR Valve, I believe the EGR Valve also throws a 0420 code. Take it off and see if it is carboned up. Clean it if it is. I'm not refuting the cat at all, but the EGR is something to check too. )
KWJR86
07-12-2021 12:31 PM
dfriz
02-07-2010 04:41 PM
kweef
07-20-2008 08:27 PM
04 Intimidator
09-18-2007 07:06 PM
sporges
03-25-2005 12:29 AM
Quick Reply: oxygen sensor problem
