My L67 swap story/thread... (lots of pics)
#42
Nope, not since I did the swap. I built the car more for street crusing, and I don't even have slicks. I'll probably take it at some point, just haven't got around to it yet.
#43
Help L67& 4t65hd swap into 5th gen 3100 ls
Hi all !!
Been lurking on this sight for years finally able to post here is wat I have 1998 M/C ls and have doner engine from 2000 Regal GS have everything trans hoses ,power steering hoses , as well as pcm out of regal . I do no not have the wiring harness from a 5th gen z34 so my question is can I use the regal harness and 2nd were do I start ?
Thanks for any help in advance !!
oh and yes that's a 97 gtp in the middle
Jim
Jim
#44
Quite the collection and quite the project. I know there is at least one 5th gen owner who swapped an L67 into his on this site. Hopefully he can fill in some gaps on the wiring.
#45
My current harness is from a GTP, modified by Milzy when I bought the engine. If I had to guess, there's an issue with the connection to the PCM, since the PCM is mounted in a different location than your Regal harness.
#47
Hi all !!
What you're talking about may be cheaper, but its going to take a bunch of labor to obtain both wire diagrams and modify it to be correct. Modifying harnesses was the #1 cause of bugs & issues in the early days of 5th gen swapped Montes. Just not worth the effort IMO, especially when some years of these cars came with almost the exact same engine.
#48
You need a 98/99 monte or lumina harness to make it 99% plug and play.
Blazed SS
13
09-26-2012 01:32 PM
