6th Gen ('00-'05): L67 swap kit and codes
the map adapter is just a plug and play extension. the boost bypass needs tied into the pcm connector (clear connector pin 77) is the boost control solenoid valve control pin on the pcm.
see attached pdf for a whole pinout diagram of your pcm
Opinion Needed: L67 Top Swap vs. L36 Bolt-on kit
Johnlh97
37
12-16-2017 09:02 PM
dgm
05-26-2014 10:11 PM
