6th Gen ('00-'05): L67 swap kit and codes
Old Jul 28, 2015 | 03:33 AM
domo_smash's Avatar
Default L67 swap kit and codes
Can anyone tell me how to use the l67 swap kit on zzp for the map wires...I also am getting codes back p0107 and p1107 please kno if you can help
Old Jul 30, 2015 | 01:19 PM
turbo monte's Avatar
the map adapter is just a plug and play extension. the boost bypass needs tied into the pcm connector (clear connector pin 77) is the boost control solenoid valve control pin on the pcm.
see attached pdf for a whole pinout diagram of your pcm
File Type: pdf
Johnlh97
40
Jun 19, 2025 11:55 AM
dgm
May 26, 2014 10:11 PM
Dam20735
Feb 7, 2013 10:28 PM
LW57912
Jun 10, 2011 11:28 AM
roadshoptuner
Aug 2, 2006 12:53 AM
