How to replace a fuel pump on a 00' monte carlo ss
Old 03-18-2010, 08:22 AM
DIGIMURDA's Avatar
Unhappy How to replace a fuel pump on a 00' monte carlo ss
hi.
i have a 2000 monte carlo SS and need to replace the fuel pump through behind the back seat.... can anyone please give me any instruction on how to go about doing this? also on how to replace the fuel filter and location?
thank you.
Old 03-21-2010, 06:50 PM
The fuel filter is located on the drivers side on the rear chassis rail forward of the tire
The fuel pump is located in the fuel tank, remove the trunk floor carpet, then the fuel pump access panel, the fuel pump retainer ring can be accessed through the panel, clean the area before removing the pump and sender assembly, replace the "o" ring seal when replacing the assembly, the pump and sender assembly will spring up when the retainer ring is removed
Old 03-22-2010, 11:26 AM
DIGIMURDA's Avatar
ok,
i replaced the fuel pump, but now for some reason my gas gauge is reading crazy, its always on either empty or full, and sometimes it moves around, did i do something wrong?????
Old 03-22-2010, 09:53 PM
possibly got the float hung up on something or bad connection at the assembly connector? Did you replace the whole assembly or just the pump? Check for proper ground at the assembly (the whole thing works on a variable resistor to ground)
Old 03-22-2010, 10:29 PM
Most likely a dirty ground.
ReaperSS
08-29-2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
01-26-2014 05:54 PM
mwjames
12-24-2013 10:10 PM
Chris s
01-29-2013 11:11 AM
augle27
03-14-2011 01:42 PM
Quick Reply: How to replace a fuel pump on a 00' monte carlo ss
