How to replace a fuel pump on a 00' monte carlo ss
hi.
i have a 2000 monte carlo SS and need to replace the fuel pump through behind the back seat.... can anyone please give me any instruction on how to go about doing this? also on how to replace the fuel filter and location?
thank you.
thank you.
The fuel filter is located on the drivers side on the rear chassis rail forward of the tire
The fuel pump is located in the fuel tank, remove the trunk floor carpet, then the fuel pump access panel, the fuel pump retainer ring can be accessed through the panel, clean the area before removing the pump and sender assembly, replace the "o" ring seal when replacing the assembly, the pump and sender assembly will spring up when the retainer ring is removed
possibly got the float hung up on something or bad connection at the assembly connector? Did you replace the whole assembly or just the pump? Check for proper ground at the assembly (the whole thing works on a variable resistor to ground)
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
6th Gen ('00-'05): To replace or not to replace Fuel Pump Module?
Chris s
Jan 29, 2013 11:11 AM
augle27
Mar 14, 2011 01:42 PM
